what heads
Old Jan 11, 2009 | 10:16 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
what heads
im in the process of putting together my 383 stroker
i was figuring out my compression ration and with a 64cc head compression is 10.6 to 1 and with a 72cc head its about 9.9 to 1
its going to be a daily driver on pump gas and im only going to spin it 6300
so what im askin is
A. 10.6 to 1 too much compression with a cast head
B. wat are some good 72 cc heads
all input welcome
zig
Old Jan 11, 2009 | 10:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: what heads
10.6 is kind of up there for an iron head.
Old Jan 11, 2009 | 10:55 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Re: what heads
I purchased a set of patriot performance alum. heads and was really happy with the quality and performance, and 10.6 is not to much compression for an alum. headed motor with a decent cam.
Old Jan 11, 2009 | 11:53 PM
ziggy89's Avatar
Engine: 383
Re: what heads
does anybody know much about the dart iron eagle heads
Old Jan 12, 2009 | 11:15 AM
bart91406's Avatar
Car: 91 rs
Transmission: th350
Re: what heads
Dart iron eagles are good heads, and will make good power, but I would much prefer to run an alum. head so you can have better compression. The dart alum. heads are not enough cheaper than afrs for me to want to run them, The Patriots are cheaper than either and will outperform the Darts from what I have seen, but you may get different opinions on this. I would reccomend vortecs on a budget, Patriots if you want aluminum, and afrs if you really want it to run awesome.
Old Jan 12, 2009 | 01:48 PM
ziggy89's Avatar
Engine: 383
Re: what heads
id luv to have a set of aluminum heads but its not in the budget and its a daily driver
i asked cause i found a set of bare iron eagle 72cc chamber 180 intake runners for 350 plus shipping out of the box
Old Jan 12, 2009 | 03:34 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: what heads
i run the iron world products, with 202 1.6's with 11:1 no problems. they are pretty worked over on the runners at 220cc, i suppose that is irealivent to compression/detontaion if thats why you are worried.
oh thats on 93 pump gas, i have ran 91 in a few times without any detonation as well.
Old Jan 12, 2009 | 04:33 PM
bart91406's Avatar
Car: 91 rs
Transmission: th350
Re: what heads
If you do want to run motown 220 or sportman 2s , call the engine shop and ask about cosmetic blem heads, I know you can get huge discounts!
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
