How to recognize 350 tpi
Old Mar 4, 2009 | 08:29 PM
cmtison's Avatar
Car: 1992 B4C
Engine: L98 soon to be 383
im new to the camaro industry and im looking for a third gen i am currently considering a 91 rs which i know doesnt come stock with the 350 tpi. however, the seller says its a 350 and for all i know it could have been an engine swap. All i can tell by the picture he sent is that it has a tpi. but gm also put out a 305 tpi for the RS version so how can i tell if it is a 350 or 305 w/o looking at the vin number.
Old Mar 4, 2009 | 11:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The factory never put a 350 in the RS, and no TPI in the RS. See https://www.thirdgen.org/1991-chevy-camaro .
The 305 TBI may have been replaced with a 350 TBI, or even a 350 TPI. But, TBI vs. TPI is very obvious - the TBI has an air cleaner that looks like a carb air cleaner, TPI doesn't have an air cleaner over the engine. 305 vs. 350 is a little more subtle -the only way to know for sure is to get the casting # off of the block and heads. The last 3 digits of the block casting # are usually cast into the side of the block under the heads. To get the head casting #, you have to pull the valve covers.
Old Mar 5, 2009 | 09:54 AM
cmtison's Avatar
Car: 1992 B4C
Re: How to recognize 350 tpi
the car im looking at has a vin number 1G1FP2383ML123694 which when i checked it said that it was a z28 the owner clains it is an rs here is a link to the ad http://phoenix.craigslist.org/wvl/cto/1058018908.html however in the picture he has purple ground affects so i am assuming that it was in an accident and he replaced the ground affects carfax said it had 24 hits any any feedback on if this is shady or not would be helpfull. thanks
Old Mar 5, 2009 | 11:48 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If it is an RS, it was NOT built with a 5.7L nor with TPI. On '86 and later blocks, you can look down behind the driver's side cylinder head and the displacement will be cast into the block. You should see 5.0LG. That's the 305.
Old Mar 5, 2009 | 01:50 PM
five7kid's Avatar
From the pictures it's clearly a TPI engine. But, it also has RS badges. The "8" for the eighth character of the VIN matches 350 TPI.
This isn't adding up.
Old Mar 5, 2009 | 02:31 PM
cmtison's Avatar
Car: 1992 B4C
i know thats what i was thinking when i saw the "8" too. If you google the whole VIN it shows up as a z28 so i think he must have used some ground affects off a purple camaro. which leads me to belive it was in an accident. in any case i dont think he knows what type of car he has.
Old Mar 5, 2009 | 11:20 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
B4C edition cars could come with the 350 TPI or the 305 TPI and still be RS cars. Check the option codes.
Old Mar 5, 2009 | 11:30 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Seems we have a B4C camaro on our hands here. In that case, rare find and you should snag it up.
Check the RPO sheet in the rear glove box. Is there a "B4C" and "1LE"?
Old Mar 5, 2009 | 11:48 PM
cmtison's Avatar
Car: 1992 B4C
if it is a B4C camaro would the vin number say that it is a z28? i dont know anything about the B4C's. but i may be wrong in the assumption that the vin number would recognize it as a B4C and not a z28.
Old Mar 5, 2009 | 11:50 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'm thinking the same thing... the B4C was a Z28 dressed up (down?) as an RS. Thats probably the case here.
Old Mar 5, 2009 | 11:52 PM
cmtison's Avatar
Car: 1992 B4C
so how can i know for sure it is a B4C by looking ? pics diagrams of what to look for
Old Mar 6, 2009 | 12:03 AM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
You need to look at the RPO code list. If it has a B4C option code in the list, then it is legit. B4C is a Z28 with RS badges. It was only offered to police and government agencies. They are pretty rare. in 1991 there were only about 600 made. So go check it out. It could be a real find. I have a 1992 right now. here is a pic of mine. By the way this might be one that I have owned. PM me with your # and I can tell you what i know about it if its mine. you can also check and see it has rear disc brakes. all 1991 350 camaro's have them.
Old Mar 6, 2009 | 12:07 AM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
the vin will say its a z28. when the insurance company runs the vin they will be charging you for a z too.
Old Mar 6, 2009 | 12:22 AM
cmtison's Avatar
Car: 1992 B4C
im a little new to this so i'm not that sure what or where the RPO code list is.
Old Mar 6, 2009 | 12:34 AM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
the rpo code list can either be in the glovebox between the two fron seats or it can be in the rear cargo compartment (the one that needs the key)
Old Mar 9, 2009 | 11:12 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Not all police package B4Cs had 1LE.
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
