L03 to L05
Old Mar 4, 2009 | 09:15 PM
kazer's Avatar
L03 to L05
I have a 92 RS Camaro with an L03 and 700r4 that barely runs. I also have a 93 Caprice LTZ with an L05 and 700r4 that is falling apart, but runs great.
The Camaro has strange issues that started recently, loss of power, backfiring randomly through exhaust or intake, bogs when given gas, etc. We have checked timing, run injector cleaner, check ignition components, and it is stumping us. I think it may be the computer. So, since I would like a 350 in the RS anyway, I am going to just throw in the L05. Question is, will the computer for the Caprice work in the Camaro? Will it hook to the wiring harness and everything?
Side question, what kind of mods could I get away with without changing the chip? LT1 cam? maybe L98 heads?
Thanks a ton!
Old Mar 4, 2009 | 09:41 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: L03 to L05
The computer in the camaro now will work with the 350. I believe you need the knock sensor from the caprice
You can do all types of mods to you car without chipping and it could run fine, but to squeeze all the hp and tq out of the mods tuning will be required.
l03 to l05 is pretty strait foward.
Old Mar 5, 2009 | 07:13 AM
kazer's Avatar
Re: L03 to L05
But if the computer is bad I'd like to use the caprice one, is there no chance of that working?
Old Mar 5, 2009 | 11:40 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: L03 to L05
You can try, I know these cars and the computers are very finiky. Took the computer from a 91/92 z28 and it would not work for my 88 camaro, but worked fine on my 89 RS.
The 89 RS and the 91 z28 computer both did not work in the 88 Camaro.
Even if it has the same plug in, it might not work, just FYI
Hopefully it does work for ya !!
Hope one of the computer guys will chime in for ya.
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
anesthes
Sep 21, 2015 10:24 AM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
