Problem!
Old Mar 14, 2009 | 05:59 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Problem!
I'm doing an engine swap from a 1987 305 TPI engine to a 1989 Corvette TPI engine.
The intake manifold on the 87 has some sensor that the 89 doesn't. It's on the right side of the manifold.
If I'm using the wire harness from the 1987 onto the 1989 engine and computer will it be a problem?
Old Mar 14, 2009 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like the cold start injector.
Old Mar 14, 2009 | 06:21 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Problem!
That's what my mechanic said, so he is changing the manifold off the 87 to the 89.
Is that the right thing to do?
Old Mar 14, 2009 | 07:24 PM
five7kid's Avatar
If you're using the '89 computer, it won't have any use for the cold start injector.
I would assume the harnesses would otherwise be pinned the same, but I don't know that for a fact. A circuit diagram of each system would be in order.
Or, ask on the TPI forum if an '87 harness will work with an '89 engine & computer.
Old Mar 14, 2009 | 07:57 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Problem!
Alright then so just leave everything as it is?
The mechanic is worrying about my check engine light is gonna be on because of that ninth injector. Is this true?
Or is the computer not even going to be looking for that ninth injector?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
