305 tpi to 350 tpi
Old Mar 14, 2009 | 01:12 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
305 tpi to 350 tpi
I will start with that i am thinking of buying a trans am 86 its a 305 tpi but doesnt have the manifold, dash and shifter for 600Dollars and i have a 89 iroc 350 tpi engine i bought a month ago for $400 now i wanted to know if it would be able to work on it and if you guys know any one who knows around LA county in California i would really appreciate it thank you guys for the advice.(In advance0
Old Mar 14, 2009 | 09:58 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It'll work.
Old Mar 14, 2009 | 02:13 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 305 tpi to 350 tpi
Would it be a problem if i keep the computer from the trans am or should i put the one from the 350 and would it bolt to the trans it has and what other things would i need other than what i have the trans am is a tpi too
Old Mar 14, 2009 | 05:15 PM
five7kid's Avatar
Only if you used the '86 TPI hardware. You can use the 350 injectors in the '86 TPI. The '89 base is slightly different, but you can put the rest of the '86 hardware on it.
Old Mar 14, 2009 | 11:39 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
So it would be better if i swap everything instead right are the trans am and camaro engines the same and how hard is it to do this kind of swap or should i get a mechanic to do it
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
