L98 or LB9, How to identify
Car: 1982 Trans Am, 1986 Gmc sierra
I just picked up a 87 trans am gta, i was told by the previous owner that it had the 305tpi in it but he was told by the guy he bought it from that is had been swapped to 350tpi. I looked up the vin code and verified that it originally came with the 305tpi. I cannot tell the difference between the two by looking at them.
Can anybody tell me how to distinguish between the two motors without finding the block number. I will post pictures ASAP.
The car definitly pulls hard, but ive never before driven a trans am so i wouldnt know the difference. Thanks, Josh
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: L98 or LB9, How to identify
This is rather easy. Get a flashlight and peer down behind the driver's side cylinder head. a 305 will have 5.0LG cast there, the 350 will say 5.7LG.
I cant find it, i did a full tuneup today and couldnt find it. Is it near to firewall? Is it on the top or bottom. Thanks, Josh
Transmission: 4L80E/4L80E
Near the firewall. Almost under the firewall.
Another possibility is to look for a 3 digit number cast into the side of the block. You'll have to look for it from underneath. Get that, and we'll be able to tell you which it is.
Can anybody tell me exactly where these two numbers are, ive searched everywhere, ive scraped the dirt off, used mirrors. Its ridiculous, should be easier to identify than this. Thanks, Josh
Car: 1990
Axle/Gears: stock
http://www.google.com/search?hl=en&r...numbers+gm+350 is the link that talks about where gm puts the numbers on gm blocks. see i even did the google search for you.
if we tell you, you will just forget.
if you find it yourself you will be proud you could find it and you will never forget.
good luck
tony
its on the passenger side, the tranny dipstick is close behind it, ill post a picture in a few minutes.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sorry guys but i cant see those numbers, ive worked on countless engines and have never had this difficulty, what freking moron put them under the firewall
If we know what heads are on it, we can at the very least make a good educated guess about what the engine is.
8 years ago, I picked up an '87 LB9. It had 2 different casting heads on it, one the correct 081 TPI head, the other a swirl-port LO3 head.
But, getting the head casting #'s isn't a bad idea, regardless.
Have you gotten underneath the car and looked for those 3 digits? That's a lot easier than what you've gone through so far. Have a good light with you when you do this.
I havnt tried looking for the numbers under the car, do you know where they are, thanks, Josh
Linson
Sep 21, 2015 01:08 PM
