88 350 tpi camaro worn out motor! CRATE??
Old Mar 24, 2009 | 06:29 PM
oldrtyblg23's Avatar
i need a longblock but dont know what to get does it have to be a 87 or newer block much help needed. thanks in advance
Old Mar 25, 2009 | 06:32 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: 88 350 tpi camaro worn out motor! CRATE??
it doesn't have to be but it will be a better engine due to the one piece rear main and roller cam. if your car has an 87 or newer block with perimeter bolt heads (doubtful, all smallblocks 87-now have centerbolt heads), then you could get the same block as a crate shortblock and swap over your heads so you can keep using your factory intake manifold.
Old Mar 25, 2009 | 09:40 AM
so would an older block with the first vortec heads work?
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
