need help fast
Old May 1, 2009 | 08:09 PM
JDCamaros's Avatar
Car: 87 camaro,93 lesabre
Engine: 305, 3.8,
Transmission: 700r4 vette servos
need help fast
ok i blew my intake gasket on my 305 so i put a performer intake on it i have a 650 holley carb with a spacer. now it will shut off after about three miles any ideas?????? it will sit there and idle all day it only when im driving. no air leaks.so im at a loss
Old May 2, 2009 | 02:46 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: need help fast
If your timing is not set right, or your idle is too lean, it can build too much heat in there, causing something like a sharp edge, or a carbon build-up, or even part of the spark plug, to get hot enough that it keeps igniting without the regular spark. This is called dieseling or run-on. I'm not sure this is what you have, but this is possible.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
