383 motor help
Old May 17, 2009 | 02:58 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
383 motor help
ok i found this motor online its a 383 cleaned, line hone, bore, hone, install cam bearings, expansion plugs and assembled. the parts included are listed below and also i want to kep this tpi so far i have a ported plenum,52mm throttle body, slp runners,edelbrock base, afpr,24lbs injectors, and a magnaflow what else would it take to get this motor in my car running correct
383 Stroker:
  • Patroit Freedom Alum. Cylinder Heads
  • 2.02 SS intake valves, 1.60 SS exhaust valves.
  • Screw in studs. 64cc chamber, 188cc intake volume
  • Bronze valve guides
  • 1.26OD valve springs
  • GM Block Bored, Honed, Decked and Align Honed
  • Enginetech Teflon Cam Bearings
  • Melling Performance camshaft:
    • 2.04/2.14 @ .050
    • .443 lift
    • 112 lobe center
  • Matching Lifters and Springs
  • New Crankshaft with 3.75?ǥ stroke
  • New Eagle Rods with ARP Rod Bolts
  • Crankshaft Micro-polished less than a 12 RA finish
  • Keith Black Hyperutetic Pistons with Molly Rings:
    • 9.2 to 1 compression ratio
  • Balanced Rotating Assembly
  • New Melling Timing Set
  • New High Volume Oil pump
  • New Complete Gasket Set
  • New hardened push rods
  • New ARP Head Bolts
  • 100 lbs. Springs
  • Screw-in Rocker Studs
  • 5 Angle Seats
  • Clevite Rod and Main Bearings
  • Positive Seals
  • Gasket Matched Ported Intake Runners
  • Professional Products Intake manfiold
  • Crane 1.6 roller rockers
  • Guide Plates
Old May 17, 2009 | 09:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's a fairly mild cam, so what you have might support it.
A Holley/Weiand Stealth Ram would be the better choice.
Not that it makes that much difference, but I assume the listed cam lift is with 1.5:1 rockers.
Old May 17, 2009 | 02:36 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: 383 motor help
yes and 1.6 rr are included
Old May 17, 2009 | 02:37 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: 383 motor help
so this will work nothing else needed. worst case senario what else could i poribly need
mhatfield 14
Oct 24, 2015 07:48 AM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
