350 GMPP Crate H.O - 330 HP
Old May 29, 2009 | 03:13 PM
'84Z28's Avatar
Car: '84 Z28
Axle/Gears: 4.10 10 bolt
Hello all,
After putting the used 350 into my car with a XE-274 and stock converter, I wished I had went with a higher stall. (500 RPM idle. WOO!) Anyways I'm going to trash the 350 due to lifter tick, very low oil pressure and lots of blow-by. (If anyone wants it it's yours for $500) I'm tired of disappointments, so I want to go with a Crate GM H.O 330 HP engine this summer. My question is, what stall converter would match up to this cam? Dual Pattern Cam (Lift: .435" Int/.460" Exh, Duration @ .050": 212° Int/222° Exh) I don't know much about cams and don't want to make the same mistake twice. Thanks for the help!
Old May 29, 2009 | 04:51 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 GMPP Crate H.O - 330 HP
For less money you can get a new 12530282, which is the same long-block assembly except it comes with the hydraulic roller lifters and all the stuff they require. For $2185, it's a much better deal.
Old May 29, 2009 | 07:31 PM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
2500 stall should work.
Old May 30, 2009 | 01:44 AM
'84Z28's Avatar
Car: '84 Z28
I have a feeling I'd want to tear into the engine you're referring to in search of a few more ponies. I want an engine I don't ever have to touch. Yes, the engine would save me roughly $500, but the hassle of getting more power out of it doesn't seem worth it. I had my fun experimenting with my last engine, and even with professional help it still ended up badly. It's time for something reliable that I won't have to tinker with. When I can afford to tear an engine apart multiple times I'll buy a builder.
Old May 30, 2009 | 09:59 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
if you want reliability you don't buy an engine with non-roller lifters.
Old May 30, 2009 | 11:46 AM
'84Z28's Avatar
Car: '84 Z28
What's wrong with non-roller lifters? I don't know much about engines so don't think I'm challenging your intelligence by any means, but I know many many engines were non-rollers and had no problem pushing 200k+ miles. One of which I know personally to be the $1519.99, questionable 260 hp engine from Jegs. Over 100k on that engine with no problems. If I could afford risking voiding the warranty on a crate then I would go with the one you're suggesting and put in different parts, but to me the warranty is one of the biggest reasons to buy a crate.
Old May 30, 2009 | 12:47 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The trouble now with non-rollers is the oil companies took all the ZDDP out of the oil. Yes, you can buy bottles of additive and pour one in every time, but there still remains the possibility of killing a lobe, then you create so much metal debris that it clogs the filter and the bypass opens, then you send the metal all through the engine. With roller lifters, this absolutely cannot happen. It's entirely up to you, and you may never have a problem, but too many of my customers have.
Old May 31, 2009 | 02:33 AM
'84Z28's Avatar
Car: '84 Z28
What do you think about long term usage of diesel oil in a flat tappet engine?
I read in CarCraft about the "330 HP GM H.O" actually being a little underrated from the factory; what do you think the 12530282 could make in comparison to it with no internal mods? Also, would it even be worthwhile if left stock in a car application? I think you're starting to sell me on this engine, but I just thought of something... What's the best intake manifold for this engine?
Old May 31, 2009 | 02:42 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
For an Intake i would go with a Edelbrock RPM Air Gap they perform relentlessly.
Old Jun 1, 2009 | 04:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No problem, especially if it's synthetic diesel oil.
Old Jun 1, 2009 | 04:36 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Are you guys aware that they just took half the remaining ZDDP out of new Diesel oil? If you wanna run a non-roller, I suggest running Royal Purple.
Old Jun 1, 2009 | 04:57 PM
'84Z28's Avatar
Car: '84 Z28
I like the idea of the roller crate 12530282, but what kind of power could I expect out of it stock with just a RPM Air Gap, Holley DP, an aftermarket ignition, and full 3" exhaust?
Old Jun 1, 2009 | 05:24 PM
five7kid's Avatar
AMSOIL has both the newer lower ZDDP diesel oil, and the "full strength" diesel oil available. http://www.amsoil.com/a/Synthetic-Di...Oil-Engine-Oil I use this product http://www.amsoil.com/storefront/hdd.aspx in my one remaining flat tappet engine, which just happens to be my "race" car. No reason to panic, just be aware and know what you're getting.
I haven't been hearing very encouraging things about RP lately.
Old Jun 1, 2009 | 09:18 PM
'84Z28's Avatar
Car: '84 Z28
What intake would match the 12530282 crate?
Old Jun 1, 2009 | 10:36 PM
five7kid's Avatar
A Vortec intake. The specific one depends upon the cam you end up using.
Old Jun 1, 2009 | 10:59 PM
'84Z28's Avatar
Car: '84 Z28
I wanted to stick with the stock cam.
Old Jun 2, 2009 | 09:54 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Good to know about Amsoil, thanks. Is Royal Purple under new management, or using a new supplier or something?
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
Vojtush31
Oct 11, 2015 01:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
