700R4- what makes it shift?
Hi all,
just swapped a carbed SBC V8 into my V6 injected bird. used the 700R4 i had gotten with the engine, carbed it and it runs. BUT the trans does not shift....
ALSO, I swapped the V6 plastic gear for the V8 from the bolt inside the rear of the trans on driver side,,which looked the same size.
SO what gets the trans to shift??
Could the gears be so little different that it can be stopping it???
Or could the trans be bad???
Please let me know of ideas or advice.
Thanks,
Ron
Thanks,
Ron
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: 700R4- what makes it shift?
the plastic gear in the tail house is the speedo gear, you need to put the original one back in it, unless you changed the rear end gears, then you need to figuere out the proper set of gears, you have to have the gears mesh properly
do you have the TV cable hooked uo, a TV cable is 100% GOT TO HAVE
will it go through the gears manualy, or does it always stay in 1 or what gear
Car: 91 rs, 97 firebird
Engine: 3.1, 5.7
Transmission: both 700r
yep and if isnt set just right you will burn it, gone threw 2 on the gta, getting ready to put another one in, and if its not set right you will burn the clutches in a matter of miles and it wont go from 2nd gear to 3rd gear.
OK. WIll put the original gear back in. Will I have to drain the trans fluid to do this???
TV Cable...which is that? I plugged both plugs into the trans...what else?? what does it look like?
thanks guys!
Ron
thanks guys!
Ron
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
there should be cable that goes from the passenger side of the trans up to the carb. if its not there it's not gonna shift
as for the TV as said it goes in the passenger side of the trans, it looks alot like the kick down cable on old trans but its not a kick down, it regulates the trans, its like the computer for lack of better words
Holy cow!...I thought it was the kickdown!!!
OK, so do NOT have it hooked up....it doesnt reach to the rochester carb i have....ANY IDEAS? maybe an extender of sorts
thanks,
Ron
thanks,
Ron
they make a kick down cables that are adjustble
let me do some looking and i will post back up
here try this link out
http://cgi.ebay.com/ebaymotors/B-M-7...1%7C240%3A1318
you may want to ask if it will work on your set up
Engine: 3.1, 5.7
tv cable, kickdown cable, and d-tent ( or something like that) are all the same, it regulates when it shifts and at what rpms it shifts, you can pick a brand new one up at at chevy dealer for around fifty dollars, can find them in a parts store though. and when you install make sure your rubber seal( looks like a litte top hat) is good. there easy to take off but a pain to hook together. goes from back passenger side of tranny to top of intake hooks on by your throttle, thats about all i know about them, lol
Car: 89 GTA/89 GTA
Engine: L98/lt1
Transmission: 700R4-
Axle/Gears: 3:27/3:73
while that cable does have to be hooked up,that is not what is causeing your trans to not shift.there is a plastic gear on the governer that gets old and falls apart, the governer is what makes the trans shift.on the drivers side of the trans towards the rear but before the tail housing there is a round cap (about the diameter of a roll of electrical tape)pop that cap off and slide the governer out and you'll likely find the plastic gear on the end either stripped or completely broken.
Transmission: 4L80E/4L80E
That is only true of the TV cable, not the "detent" or "kick-down" cables of yesteryear.
That is NOT true! A "detent" or "kick-down" cable only tells the transmission to shift down at WOT. The throttle valve varies internal transmission pressures based on throttle position (hence the name), and if not installed or properly adjusted, you can easily ruin your TH700.
thanks guys!
redfox, thanks for the PM, but havent had a burning question yet, but will if I do.
89RS - that link was great and I found it on summit for cheaper. they did say it would fit a rochester Qjet. but I am going to look into getting it to fit without this....
does the length of the TV cable matter?? theortically, couldnt i just extend the cable??
as long as the cable is pulled all the way at WOT it will be fine?
what about at idle, does the cable need any tension???
thanks guys!
Ron
thanks guys!
Ron
The cable needs to be fully extended at WOT, but where it is at part throttle is critical - that's what we've been trying to say.
That is more of a matter of the throttle arm geometry than length of cable. If it is a stock carb, no problem. Otherwise, you'll probably need a "geometry corrector" bracket. But, since you said "Rochester", I assume it is a stock-type carb.
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
I didn't have time to wait for a geometry corrector to get shipped when I swapped carbs on my K5 blazer, so I just took measurements off my stock Q-jet, drilled and tapped a hole on my holley's throttle linkage using the measurements, used a small bolt for a stud, and wala, it worked fine, put 5000 miles on the truck before I sold it(to buy my camaro
) and no problems what so ever.
) and no problems what so ever. Supreme Member
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
It's probably the detent cable.. But when my shifter linkage broke I was stuck in 1st... Maybe check the linkage, too.
If it's a TH700R-4, it doesnt have a detent cable!!!!!
To replace the TV cable, you have to remove the retaining bolt for the housing at the transmission, then disconnect the cable from the internal hook. It is possible to do it from the outside, but it's probably going to be easier to drop the transmission pan and replace it that way (time for a fluid & filter change anyway, right?).
wondered why the tires moved so slow...didnt realize my rear drum spring broke and was braking the drivers rear the whole time....
so jacked it up and pulled the brake....
**DOES the TV cable stop it from shifting???
b/c i put it in first, then second, and it moved faster....but this was kind of manually...
Is this normal without the cable??
So, I put the plastic gear in and the speedo works...not sure on the accuracy though...
Summit has the cable and they say it will work...ordering now.....
all the TV cable does is tell the trans when to shift, and how much pressure to put on the clutches. it MUST be hooked up or you WILL BURN UP YOUR TRANSMISSION
thanks much guys!
summit says the cable should be here friday...so hopefully it will get done this weekend...
five7kid....is that really it for procedure??? anything else?
thanks,
Ron
thanks,
Ron
Car: 1992 RS camaro
Engine: chevy 350
Axle/Gears: 3.73 axle
hey i just dropped a 350 with a 700 R4 into my 92 3.1 liter camaro, and after reading about you guys talking about the kick down cable, you kinda worried me. i made a bracket for it to work on my holley carb, but how do you adjust the cable or put it in the right spot. my dad said it doesn't do much but just tells the tranny when to down shift, at WOP. is that right, my car is like 2 days from done and i dont want to smoke the tranny
Unless you have a q-jet, you need a "geometry corrector" bracket on the throttle arm of the carb. There is a different one for Holley and Edelbrock carbs.
To adjust the cable, depress the "D" button on the cable housing connector at the bracket and pull the cable housing back at the same time. Let go of the "D" button. Floor the accelerator. The housing will ratchet forward and is then in the correct adjustment.
maybe someone will read it this time-
700 R4 transmissions DO NOT HAVE A DETENT OR KICKDOWN CABLE!
They have a throttle valve or TV cable that MUST BE HOOKED UP, or you will DESTROY YOUR TRANS.
Car: 1992 RS camaro
Engine: chevy 350
OKAY I am not an IDIOT, there is a cable on my transmission, i was reffering to it as a kickdown cable. MY BAD. i am just asking on where it is possition compared to the accelorator, is it suppose to be all the way out when the throttle is? I am not sure just asking
Everything you didn't want to know about TV cables. Part 1, 2 & 3)
http://www.tvmadeez.com/article/index.php
dhonda200
Aug 11, 2015 11:50 PM
