Corvette L98 into 1991 Z28 Trans ?????
Old Jun 25, 2009 | 08:12 AM
Burbo's Avatar
I have a 1991 Z28 with a 1986 Corvette L98 5.7 TPI and transmission my problem is i don't know how to mount the transmission to the the camaro should i try Jegster's universal cross members. Does any one know where i can get a diagram or a picture of how it was mounted in the Corvette
Thanks for your help
Burbo
Old Jun 25, 2009 | 09:47 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Corvette L98 into 1991 Z28 Trans ?????
The engine is no different than a Camaro engine and will bolt right in. What's so special about the Vette transmission? It won't have a torque arm mount on the tailshaft. Why don't you just use the F-body transmission?
A "universal crossmember" won't fit into a third gen. The best thing to do is buy an aftermarket torque arm with a crossmember specific to the type of transmission you want to use. www.spohn.net is one vendor that produces such a thing.
Old Jun 25, 2009 | 11:03 AM
Burbo's Avatar
Thanks for the tip, already placed my order. Hopefully be at the track soon
Thanks again
Old Jun 25, 2009 | 03:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Take the output shaft housing off of the '91 transmission and put it on the Vette transmission (assuming the '91 was auto).
Old Jun 29, 2009 | 06:31 AM
Burbo's Avatar
Thanks for the info but just my luck they don't make such a thing (SPOHN). I ll have to check out what Five7kid reply and hopefully that works out, stay posted
Thanks again veryone
Old Jun 29, 2009 | 12:43 PM
five7kid's Avatar
Yes they do. http://www.spohn.net/shop/1982-1992-...nsmission.html , along with their crossmember gets the job done.
Old Jul 1, 2009 | 11:58 AM
Burbo's Avatar
Do you know this for a fact five7kid That a 1991 700 R4 output shaft will bolt right up to a 1986 Corvette 700R4, I can't find this out any where, having a parts manger looking into this for me. That would be nice seeing that i need to some how hook up the Torque arm
Old Jul 1, 2009 | 12:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The 700R4 should be identical for both cars. The difference is that the third gen needs a different tailshaft housing because the torque arm needs to bolt to it. Simply installing the third gen tailshaft housing onto any other 700R4 will allow you to use it in any third gen.
If you go with an aftermarket torque arm with crossmember, you don't need to change the tailshaft housing because the new torque arm will attach to the crossmember instead of the transmission.
GM's idea of mounting the torque arm off the transmission wasn't a good idea. Mounting it off the crossmember is much better.
Old Jul 1, 2009 | 12:32 PM
Burbo's Avatar
As it stand right now with the 700 R4 from the 1986 Corvette the output shaft has no way to blot up to the cross member in a third gen (FYI)
Old Jul 3, 2009 | 12:27 AM
five7kid's Avatar
Tailshaft housing, not the output shaft.
The mount is part of the f-body output housing.
Old Jul 3, 2009 | 11:08 AM
camlass's Avatar
Car: 82 indy z
Transmission: th400
Axle/Gears: 8.5 4.88
the spline count maybe 27 on a 86 700r4. i think it was mid year 86 that gm put 30 spline over the 27. if it is a 27 you should use the f body 700r4.
Old Jul 6, 2009 | 06:51 AM
Burbo's Avatar
Thanks five7kid, I should be getting a tail shaft housing from Camaro Plus (used parts) up here in NE, so I'm hoping that the torque arm and the cross members blots up nicely. I hope the spline count doesn't make a difference as camlass has posted
Thanks again
Old Jul 6, 2009 | 01:20 PM
five7kid's Avatar
The input shaft changed from 27 to 30 spline in '84.
Old Jul 6, 2009 | 01:28 PM
Burbo's Avatar
So i shouldn't have a problem as far as this spline count goes ???
Thanks again
Old Jul 23, 2009 | 07:32 AM
Burbo's Avatar
Well couldn't get anything to work so I'm going with a new/used housing for the trans that came from a 91 Camaro so i have a little bit of a set back
Old Oct 5, 2009 | 01:52 PM
Burbo's Avatar
Well got that all done just to let everyone know, goes real good but now i have no flashers or signals so off i go to elec section
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
milk
Aug 10, 2015 06:26 PM
