Swapping a 406 in place of the 355, need help with the starter.
Old Jul 1, 2009 | 02:27 PM
'86 350's Avatar
Car: '86 Camaro SC
Allright. I'm swapping in my 406 and i've got the old 350 out. I don't have the starter for the 406, and since a T5 is being bolted up anyways, i'm using the 350 starter. My problem is that the 406 has holes drilled in the block for a staggered starter nose, while the 350 starter nose is straight across.
Since the 350 starter/T5 setup uses a 158t flywheel and i'll be using the flywheel on the 406 (got a balance plate) i'm running into a problem. I believe that all the staggered starters sold are only for the 163t setup that GM had. Is this true?
My question is, if I were to get a staggered nose starter from a car that uses a 163t setup, could I just swap on the staggered bolt nose from that starter onto the current starter I have?
-Thanks, Brandon
Old Jul 1, 2009 | 02:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Swapping a 406 in place of the 355, need help with the starter.
Only if you use it with a 163T flywheel. To use a 158T flywheel on your block, you'll need to have the missing starter hole drilled and tapped.
Old Jul 1, 2009 | 04:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
For the record, it's 168 and 153.
I'd agree your only choice is to get the other hole drilled and tapped. Best to have a machine shop that knows what they're doing do the job.
Old Jul 1, 2009 | 05:35 PM
'86 350's Avatar
Car: '86 Camaro SC
Damn, I thought those numbers looked funny. Oh well, either way I got my point across.
That sucks. Oh well, out to go pick out a new drill bit and tap. I'm assuming my standard plug in Dewalt drill will work fine.
Is there a certain type of bit (material wise) I should get? I know cast iron is a fairly soft metal, but I'd still rather not have a bit break halfway through.
Old Jul 1, 2009 | 06:06 PM
five7kid's Avatar
They aren't just plain ol' drilled & tapped holes. Go take a look at them - the top (outer) part of the hole doesn't have threads in it. That's because the starter mount bolts have a knurled shank to precision locate the starter.
Unless you have a drill press, precision drill bits, and precision reamers, I wouldn't attempt this job.
Old Jul 1, 2009 | 07:29 PM
'86 350's Avatar
Car: '86 Camaro SC
Any idea what a machine shop will charge (roughly to do this job) then?
Also, does Summit or anyone make those mini starters that would have maybe an inline and staggered bolt pattern, and that would work with the 153t setup? I wouldn't mind one of those either, it sure would make getting around the longtubes a little easier.
Old Jul 1, 2009 | 11:20 PM
five7kid's Avatar
Not sure about the machine shop charge. I'd guess in the $50-$75 range.
I looked on Summit for a staggered 153-tooth mini starter on Summit before my original response.
Old Jul 2, 2009 | 01:49 PM
'86 350's Avatar
Car: '86 Camaro SC
I called a shop today, they quoted me about $35-$40 over the phone. Unfortunately, I need to tear the engine back down to a shortblock.
Think I'll be safe re-using the the intake and head gaskets? Before this the intake gaskets were brand new and the headgaskets only had about 30 minutes of runtime on them.
Old Jul 2, 2009 | 04:59 PM
five7kid's Avatar
If the gaskets are composite (not metal only - which would only apply to the head gaskets) and come off cleanly, they can be reused.
Back in the dark ages when I was in the Army, I went through their mechanics training. At the time, they were using some Dodge trucks with 318's. They had a bunch of these engines on stands in a big open bay. We had to tear them down to the shortblock (left the oil pan on if memory serves), put them back together, and start them up in order to pass. To my absolute shock, they reused all gaskets, including the head gaskets. The engines ran fine when put back together, but they weren't exactly heavily loaded, either.
Old Jul 2, 2009 | 08:53 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
unforetuneatley ive never seen any before
Old Jul 2, 2009 | 09:33 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
I know this doesn't directly solve your problem but, from what I have heard, and experienced, the T5 behind a mild 350 can fail I would think behind a 406 it would stand very little chance?
Old Jul 2, 2009 | 11:53 PM
five7kid's Avatar
As long as you baby it (no high RPM clutch dumps or speed shifting), a T5 can live behind a 400.
Old Jul 4, 2009 | 01:10 PM
'86 350's Avatar
Car: '86 Camaro SC
That's my experience too. However, I think I've got some freak T5. My 355 dyno'd 356rwhp and 348rwtq, and the car regularly saw 3,000+ rpm clutch dumps and I slammed gears almost every chance I got. It held up just fine with regular fluid changes.
Granted, I probably will baby this T5 a little more till I save up for a T56 swap, so I'm sure it should be just fine. And if it does break, I'll just pick up a JY unit, it takes like an hour and a half to swap a transmission at the most.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
Regal105
Aug 23, 2015 03:45 PM
theurge
Aug 21, 2015 12:46 PM
