Newbi needs help!!
Old Jul 4, 2009 | 10:42 PM
slayernut's Avatar
Car: 92 rs camaro
Engine: 350 tbi
Transmission: 350 turbo with kit
Newbi needs help!!
Hi friends, I have a 92 rs camaro with a 350 tbi and 350 turbo tranny with shift kit, stock rear end as far as i know. I have been having way to many problems with the current engine, running hot , running ruff and stalling constantly. I have replaced every sensor ect ect". I want to convert to carburated ,just want my car back on the road and i have 3 options for a replacement engine fairly cheap. 1 is a 305 with 350 heads, 2 is a small block 400, and 3 is a 1963 283 with 25000 original miles. Can anyone tell me my best option as this car is an everyday driver. thank you
Old Jul 4, 2009 | 11:39 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Newbi needs help!!
For reliability and least issues, the 305 would probably net you the best option for a daily driver. As for power, the 400 would be the best, even in stock form. The 283...i would never waste my time on one.
Old Jul 5, 2009 | 09:01 AM
slayernut's Avatar
Car: 92 rs camaro
Engine: 350 tbi
Thank for the reply, think i may go with the 305 then, i can have it for a couple hundred. thanks again.
Old Jul 5, 2009 | 01:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Why not carburate the 350? By getting rid of the computer and it's sensors, tracking down the issues should be much easier (unless you think you have a cracked head or something serious). It takes all the same goodies to carburate a 305 as it does to carburate a 305, and a 350 makes a ton of difference!
Old Jul 5, 2009 | 06:58 PM
slayernut's Avatar
Car: 92 rs camaro
Engine: 350 tbi
well that was a though at first i already have a 350 intake. what all else will i need? do i need to change the heads where as the intake has a different bolt patern? I can get a set of heads for 75 bucks. will an inline fuel pump work without removing my old pump?? Thanks alot for you replies, my dodge caravan just isnt doing it for me, lol.
Old Jul 5, 2009 | 07:00 PM
slayernut's Avatar
Car: 92 rs camaro
Engine: 350 tbi
also i have had the car looked at and compression is good and everything.
rubblerubble
Mar 13, 2016 06:57 PM
R3500
Aug 24, 2015 09:05 AM
jeepman
Aug 17, 2001 08:13 AM
83Z28
Carburetors
Jan 5, 2001 05:15 PM
