305 to 350
Old Jul 22, 2009 | 12:49 AM
wesrams1's Avatar
Car: 1992 Camaro RS
Engine: 350 .060 over
Transmission: stock
Axle/Gears: stock for now
305 to 350
Im swapping my POS 305 with a 1979 chevy 350. Passing smog is a must for me so i think im going to keep the TBI set up. My question is can i take the manifold and TBI off of my 305 and bolt them onto my 350? Also i would like to make this build semi performance, will that be difficult with a TBI setup?
Old Jul 22, 2009 | 01:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
To start a '79 engine isn't legal to install into a '92 chassis.
Then, the TBI manifold won't bolt directly to the (junk) '79 350 heads without modification. In '87, the center two intake mount bolts were changed to 72 degrees.
The crank/block are 2-piece rear main seal through 1985, vs. 1-piece for '86-up. Requires a different flexplate.
The TBI forum is the better place to ask about TBI performance.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
