3.1 (189) to a 305 or 350?
Old Aug 18, 2009 | 02:44 PM
livinforhim's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6
Transmission: 700-R4
I have a 1990 camaro, with a V6 3.1. The Block is shot. brand new heads on it and it won't stop leaking coolant between the block and the head. I am about to replace the block on it. And im thinking if im about to tear it down for the third time this week and take the block out I may as well just put something with more performance in it.
What will have to be changed to convert to a 305 tpi from a 189.
What will have to be changed to convert to a 350 from a 189.
I know the ECM has to be changed can i just find a new one and plug it in? And Accersories? will brackets for A/C, Altenator, Power steering, etc. still fit? from the 189. Trans, its from the factory, 700R4 (I think), will it work with a 305? or the 350.
Old Aug 18, 2009 | 02:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Start by reading the V6 to V8 swap sticky in the top section of this forum.
There basically isn't any difference in the work whether you put in a 305 or 350.
Old Aug 18, 2009 | 02:52 PM
Car: 1990 Camaro RS
Engine: 3.1 V6
Re: 3.1 (189) to a 305 or 350?
oh well i decieded i don't want all those head aches. guess ill stick with the v6
Old Aug 18, 2009 | 03:22 PM
five7kid's Avatar
Then you might want to check out a 3.4l swap. Detailed on the V6 forum.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
