old school swaps (L98 stuff to an LG4) with a twist
Old Aug 23, 2009 | 02:46 PM
oil pan 4's Avatar
Car: 89 Firebird
This summer I over heated real bad and was going to pull the heads and do my planned aluminum head upgrade on my little 305. I go on real long road trips with my car I don't want a crack to manafest its self while several hundred miles away from home.
Now I found a nice set of aluminum L98 vette heads, but the heads I found just happen to be up graded to 2.02/1.60 inch valves.
I don't know if they would work on a 305 with the bigger valves.
Does any one know if a 305 can take these heads with 2.02/1.60 inch valves?
Old Aug 23, 2009 | 03:19 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: old school swaps (L98 stuff to an LG4) with a twist
Well, a 305 is: 305 = 3.736" bore. So, add 2.02 and 1.60 you get 3.62 inches of valve total, not to mention the valves are not exactly touching and they are off set, not centered, so no, they should not work.
Old Aug 23, 2009 | 03:40 PM
oil pan 4's Avatar
Car: 89 Firebird
Would I be any better off with standard 1.94/1.50 valve heads then?
Oh and my block is bored .020'' or .025'' over. I didn't realize it would be so close.
Old Aug 26, 2009 | 04:35 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I see them usually go with a 1.84 intake valve, but you might be ok, you need to measure everything to find out.
Old Aug 26, 2009 | 05:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Been awhile, and I haven't searched for it, but a member posted a picture of a 2.02/1.60 head mounted on an empty 305 stock-bore block looking up the cylinder from the crankcase. The valves cleared fine up to something like .550" lift.
How effective those big valves would be is a different matter. The outer edge will be shrouded by the 305 cylinder wall, reducing flow. In addition, it is pretty well established that 2.02 valves are worthless in aluminum Vette heads. If you haven't bought those heads, don't. If you can get them for free, they would be better than no heads.
Don't forget that 58cc aluminum heads are equal to 64cc cast iron heads due to heat loss through the aluminum. Your static compression ratio might remain the same as stock, but the effective compression ratio will be reduced. Shaving them down to 52cc would restore your effective compression.
Old Aug 26, 2009 | 05:43 PM
five7kid's Avatar
The factory used 1.84/1.50" valves in 305's. A common upgrade is to use 1.94" intake, and some will also install 1.60" exhaust valves. 1.94/1.50" typically work well on a warmed-up 305.
Old Aug 26, 2009 | 09:45 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Originally Posted by five7kid
In addition, it is pretty well established that 2.02 valves are worthless in aluminum Vette heads. .
Can you elaborate on this a little more? What is meant by that? Why are they worthless?
Old Aug 27, 2009 | 03:16 PM
five7kid's Avatar
Because intake valves larger than 2.00 don't improve flow regardless with these heads. And, over 1.94" intakes require very careful porting to realize any improvement.
Old Aug 28, 2009 | 07:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yep. The chambers on the Corvette heads are too small for the valves - they will physically fit, but the clearance between the valve and the side of the chamber is so close that no significant airflow gets past. Thats why the 1.94 valves are better on those particular heads.
lt500r55
Sep 1, 2021 01:30 PM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Winchester1094
Aug 18, 2015 10:23 AM
