Is it a 350???
Car: 85' Z28
Engine: bone stock 350, rochester quadrajet
Transmission: Stock 4sp. automatic
Axle/Gears: stock gears
Is it a 350???
KK..so here i am begging for u guys help once again...my camaro is an 85 z28 which i know is the first year of the tpi...i was told by a few people who claim to know the owner of the car before the guy i bought it from and am told its a 350...i know its not the stock motor unless thy went from tpi to carb..is there an easy way to tell what the motor is??
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Is it a 350???
JamesC
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Re: Is it a 350???
The block casting number is the only way to know. If you can read that while the engine is in the car, I'd really like to know your secret as I have a similar problem (my car was a 305, but now has a shortblock of unknown origin.)
Car: 85' Z28
Re: Is it a 350???
yeah, i know about the other two models...mine has the TPI badges all over..
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Is it a 350???
It's easy to fake badges and decals. A VIN code should say what the car originally had. A casting number will tell you if it's a 350 or 305 since they use different casting numbers.
Car: 85' Z28
Re: Is it a 350???
hmmmm..im surethey used different plugs for a 350 than a 305 right?? i should be able to pull a plug and compare them right???
Car: 1989 Camaro RS
Engine: 496 BBC
Transmission: T-56 6 speed
Axle/Gears: 4.11 posi
Re: Is it a 350???
check the block casting number with an adjustable mirror and flashlight (mirror is like 5 bux at an auto parts store). ive done it on carbed and tpi models with little fuss.
Car: 1987 Pontiac GTA
Engine: 350tpi
Transmission: t56 6 speed
Axle/Gears: 3.70
Re: Is it a 350???
if its not too rusty or covered with gunk on the passenger side of the block where the water pump bolts up there a flat area with numbers. the top number might be part of a vin and under that there should be more writing called suffix codes. Find em if you can and look it up online searching under suffix codes. I think theres like 6 digits mixed letters and numbers.
Transmission: 4L80E/4L80E
So much easier to get under the car and look for 3 cast-in numbers on the side of the block. They are the last three digits of the full casting #, and are all you need to identify the block on www.mortec.com - which will tell you whether it is 305 or 350.
If by chance those three digits aren't there (not sure when they started doing that), then get the full casting number from behind the driver side head.
FormulasOnly
Sep 10, 2015 09:07 PM
