Motor Swap Help
Old Oct 22, 2000 | 05:29 PM
Ryan83's Avatar
Motor Swap Help
I want to swap a 350 into my 92 Camaro equipped with a stock 305 TBI. I want the 350 to have forged pistons, forged crank, and pull as many parts off the 350 as possible. I will eventually replace the 305 parts, but cannot at the moment due to a tight budget. I may have the 350 bored .030" over but need more info. Also need info on switching to TPI. I need help on these decisions and need any info available. Please keep in mind my tight budget. Thank you.
Old Oct 23, 2000 | 12:32 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
tight budget and TPI dont match.
do you really need the forged junk? I dont use it and I know guys that blow me away and they dont use it!
Save your money for the stuff you NEED.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Oct 23, 2000 | 01:39 PM
Ryan83's Avatar
I meant I want to pull as many parts off the 305 as possible. I heard that you need the forged stuff if you are going to use NOS, I heard the cast stuff won't hold up to nitrous.Is that true, and what about the over bore stuff?
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
