Motor Mounts between v6 & v8?
Old Oct 27, 2000 | 02:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I know the motor mounts are different on the engines, but are the clamshell rubber mounts the same on the frame?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 27, 2000 | 03:41 PM
MikeS's Avatar
I think you are talking about the parts that I consider the motor mounts. If it is the part that remains bolted to the crossmember of the car, than they will have to be changed. The metal brackets that bolt directly to the engine block kind of slide down over these mounts when the engine is installed. Anyways, it is kind of tricky to bolt the new motor mounts on since you have to bolt them on from inside the hollow crossmember. It is either four or six bolts per motor mounts with nuts on the inside. Maybe lockwashers too. Hope this helps and hopefully i explained it clearly. Let me know if you need me to try again.
Mike Smith
Old Oct 27, 2000 | 05:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Tom, the only parts that are the same are the bolts that hold the mounts to the frame. Everything else about the mounts are different.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 29, 2000 | 09:13 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
And it is only 3 bolts per mount. I ended up tapeing a nylon wire tie on the threads of the bolts and sticking them up through the crossmember and motor mount from the bottom. Then I held the bolt by the threads and put the washer and nut on the top side.
Old Nov 1, 2000 | 12:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks five-seven, that's what I was after. I was looking to get those ES poly motor mounts... oh well.
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
