Big Block Questions
Old Oct 22, 2000 | 10:14 PM
RoadRacer's Avatar
Big Block Questions
Hi everybody!
I'm new to this board and I'm hoping you all can help me with a project I'm working on.
I bought an '86 GTA from a friend after he blew the motor and I'm considering putting a big block in it. I would normally just put another SB in, but I happen to have a big block that came out of another project.
Does anyone know of any resources where I can find out more about this? I know I need headers and stuff like that, but I'm more curious about firewall clearance and brake master cyl. fitting over tall valve covers, etc.
Any help would be appreciated!!!
Don
Old Oct 23, 2000 | 07:45 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
It's all on my page. I did it about 2 years ago. Let me know if you have any other questions.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
http://www.geocities.com/MotorCity/Track/5604/
Old Oct 23, 2000 | 08:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You finally beat me too it. I never checked the forums in the morning.
My big block project is underway however there's a lot of things I don't have to worry about since it's going into a total race car. Valve cover clearance from the wiper motor and heater aren't going to be a problem for me. Miles's page is very complete on how to do it.
Other than a few minor modifications, it's a direct bolt-in into a street car.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 24, 2000 | 10:37 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Normally I don't get up that early especially on a Monday.
Any pics of bbc project yet? I am picking up my car from the painter tonight. Should have some pics tomorrow.
Miles
Old Oct 24, 2000 | 08:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The block is still at the machine shop. The balancing wasn't done yet last weekend.
I never considered doing a pictorial of the installation. Just what the final engine will look like before it's dropped in. I don't have a digital cam yet so pics would have to wait until the entire roll of film is done or the engine is finished. Whatever comes first. But I suppose I could take pictures. Of what though? The engine buildup or just how to install it in the car? Don't forget, this isn't a street car so my installation won't be the same as everyone elses.
Old Oct 26, 2000 | 01:56 AM
Russ-So Cal's Avatar
I see you live in Santa Barbara. If you put a big block in it, and want to drive it on the street, you'll have to swap your small block back in every two years to get past the smog *****.
Old Oct 30, 2000 | 09:00 PM
RoadRacer's Avatar
Sorry I haven't replied, I've been out of town.
Thanks everybody for your input on this. It will certainly come in handy.
As for smog, I'm not concerned about getting the car to pass. I have a couple of friends that owe me favors.
Don
Old Nov 3, 2000 | 04:16 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Miles and Steve,
Which Trannys are you using in your BB 3rd gen cars and will the 1LE driveshaft work with a stout 10 Bolt rear or is a 'custom' DS required?
I'd like to some more motor shots of both your cars!!
Thanks!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190s, TPIS ZZ-9, Edelbrock RPM intake, TES and Edelbrock 750 cfm Carb (#1411), stock T-5, 3.42 rear GM gears w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
[This message has been edited by Phil87IROC (edited November 03, 2000).]
Old Nov 3, 2000 | 08:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The tranny position doesn't change when installing a big block. I'd like to modify the firewall and push everything back about 6 inches myself. Miles has a TH400 and I use a TH350 long tailshaft tranny with a stock 700R4 driveshaft. If the 1LE driveshaft is the same length which I believe it is, then I could use it. The yoke on the driveshaft would have to be changed to use the TH400 u-joint.
Miles's pics are/were in a street car. Since that's what most people will have, his picks are what you need to look at. I'll take as many pics of my installation into a race car as I can. I have "lots" of room in the engine compartment to play with.
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
sreZ28
Aug 14, 2015 07:48 PM
