305 to 327
Old Nov 12, 2000 | 09:13 PM
ShadowChild's Avatar
305 to 327
just found a 327 vette motor (ls1?. anyway, i was planning on putting it in my 87 iroc. got everything figured out on how to install it but i need to know if it will bolt right up to the tranny or if i will have to change that too. not sure what tranny it is other than auto w/ overdrive. oh yeah. and we have this motor doing 400 hp. sooo, i should probably change the rearend. suggestions? any help will be much appreciated. thanks.
Old Nov 12, 2000 | 09:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
At what rpm does it make 400hp? If you plan on using it as a street engine it will only be operated below 5000 rpm anyway. The 327 is just a destroked 350. It's designed to work at higher rpms.
It's a better choice than a 305 but a 350 would be even better.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Old Nov 12, 2000 | 10:00 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Is it a 327 or a LS1?? (An LS1 is 346 c.i.)
The LS1 doesn't look anything like a small block chevy.
If it is, you would need the trans (the bellhousings are different) and all the computer and fuel management equipment off the donor car.
If its a 327 from an earlier Vette the heads shouldn't have any acc. bolt holes in them to mount the alt, etc.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited November 12, 2000).]
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
