Does someone make a steel crank for.........
Old Dec 5, 2000 | 08:29 PM
Country Boy's Avatar
Car: 2001 Camaro SS
Transmission: 6 gears to tear you apart..
383 L98 (400 SBC crank). It has to have the one piece rear main. And is it still externally balanced? I want to use a 6 speed tranny and the LT1 twin disk setup, but if its still externally balanced, I cant use the LT1 flywheel. Or can I? TIA. Im tryin to get everything straight before I jump in.
Old Dec 6, 2000 | 01:07 PM
Mark W. Winning's Avatar
Centerforce makes two flywheels for the T-56. One is for internally balanced 350's and the other is for externally balanced 400's. Several aftermaket companies make a internally balanced 383 crank that you can use the stock LT1 flywheel with. The only real problem is with the new 383 crate motor from GM. It is externally balanced AND one piece rear main. No T-56 flywheel for it yet.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Dec 6, 2000 | 07:55 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
I have a 383 MR in the works w/T56, the block is at the machine shop right now.I'm using the cast SCAT one piece rear main seal, it's good for up to 600 hp N/A and I'm installing 4 bolt main splayed caps.I have a McLeod street twin clutch (LT1) that I will be using, everything is going to be internally balance by the shop.
1987 IROC w/T56 and a 383 TPI in the works
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
Dialed_In
Aug 20, 2015 01:45 PM
Winchester1094
Aug 18, 2015 10:23 AM
