Accesories from V6 to V8
Old Jan 5, 2001 | 11:27 PM
zerogauge's Avatar
what accesories if any will swap from the V6(2.8) to a V8(5.7)?
I assume I would have to change the brackets but is their a difference between the alternator and ac? power steering pump?
Old Jan 6, 2001 | 07:10 AM
ede's Avatar
ede
alternator, PS pump, and AC should all be the same. i'm guessing the brackets would be differant since it's a 60*v6 to a 90* v8, but i'm not sure.
ICON Motorsports
1st & 3rd
Old Jan 6, 2001 | 05:00 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I don't know about the AC, but the rest of the brackets are different.
I had to change the power steering pump when I swapped the 305 for the original V6 in my 83 SC, as one of the lines was spot-welded to the side of the reservoir on the V6 unit and was in the way of the V8 bracket. I used the pump from the 84Z which 'donated' it's engine. The alternator itself will fit although the pulley may need to be changed.
Pete
Pete's Place
HiOutput <a href="http://www.hioutput.com/rpmworld.html">Virtual Racing Team</a>
<IMG SRC="http://www.hioutput.com/pics/SC.gif" TITLE="Pete's 83 SC">
My 83 SC...(originally V6) 203,400 mile LG4/5-speed from an 84 Z28, 3.42 one-tire-fryer, T-tops, PW, PH, boxed LCA's, Hedman Hedders and y-pipe, Dynomax cat-back, .420" lift cam, custom air induction .....best ET is 14.935@94.14</P>
mhaskell
Mar 18, 2002 07:08 PM
Kory-88Iroc 350 tpi
Mar 1, 2002 04:41 AM
Stormshadow GTA
Jan 30, 2002 10:46 AM
Remondi2
Apr 12, 2001 02:26 PM
