400 swap problems
Old Oct 6, 2009 | 12:48 PM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
400 swap problems
hey i am putting a 400 block into my 83 firebird and bought the hedman long tubes. i also have a th-350 trans with a 168 tooth flywheel and can't get the starter that i bought to fit. Has anyone done this before and know what starter will fit for sure before i waste money on another. thanks
Old Oct 6, 2009 | 02:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What starter did you buy?
Old Oct 6, 2009 | 02:27 PM
ejm's Avatar
ejm
Engine: Carbed 350
Re: 400 swap problems
the summit protorque starter that is adjustable. none the the different setting seem to work
Old Oct 6, 2009 | 03:00 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
I have a 400 small block w/168 flywheel and stock bbc starter with headers (short) there is lots of room. I had long tube headers for a long time but they rusted away(lots of room). I have a 700r4 trans. Only thing is the starter has to be installed or removed with the header removed.
Old Oct 12, 2009 | 05:04 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Flywheel/flexplate has to be counterweighted 400 SBC unit.....unless you've internally balanced the engine. Starter is relevent to the 400 flywheel/flexplate. The engine is the same externally and should fit with out problems.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
camaro71633
Sep 1, 2015 10:24 AM
