Would like specs on L69
Old Jan 17, 2001 | 01:15 AM
84transam2be's Avatar
Well. I'm getting a 84 trans am this summer for like 1000 bucks. mecanicals are pretty good, but I was wondering about the specs on that 4bbl HO 305. Also, can you put on 1.6 roller rockers with the stock pistons in there and have no problems with the clearance? (have a couple questions) also, it should be that borg warner T5 in there, right? it is a 5 speed. and, do you disconnect vacuum advance to set the timing?
Old Jan 17, 2001 | 10:19 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
L69 was the highest output carb 305 with an advertised 190 HP. Ive heard they supposed to be able to get into the 14.9's stock ....but I doubt yours will. Yes you have to disconnect the vacuum advance to set timing and a T5 trans would be my best guess
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
Old Jan 17, 2001 | 10:29 AM
cool! I was looking at the specs on the page and it also apears to have a 3.73 rear. did they come with posi way back when?
Old Jan 17, 2001 | 11:50 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
There is no vacuum advance, the computer controls the advance. To set the timing, disconnect the four prong connector on the driver's side of the distributor, loosen the distributor hold down bolt, adjust timing, retighten hold down bolt, reconnect four prong connector. Yes, you can use 1.6 rockers with no problem, but if you want to use rollers, you'll need tall valve covers. Yes, it's a non-WC T5 (if OEM). The had the option of posi and 3.73 gears
George P. Lara
1984 "L69" A4
1994 LT1 M6
Member:
SCCA, SCFB, SC3GFB
[This message has been edited by MRZ28HO (edited January 17, 2001).]
Old Jan 17, 2001 | 01:48 PM
Thanks! I'll let you guys know how it comes along.
Old Jan 17, 2001 | 08:14 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
posi was optional. compression was 9.5:1. I would cam it instead of rockers, although the L69 in the f-bodies got a better cam than the cam in the Monte SS.
T5 was used 83-92; 84-92 was hydraulic clutch setup.
jmd
L69 / T5
Old Jan 17, 2001 | 11:26 PM
Mike92's Avatar
With a mild cam like the Edelbrock Performer It'll take out a Stock 96-98 4.6GT Coupe 5-speed. I'm sure there is alot of them around where you live too.
Old Jan 18, 2001 | 01:25 PM
Well. I'm sure a cam swap is pretty involved affair, so if I do that I'm gonna make sure I have the beans to put some aluminimum heads on there. I was just intrested in the rockers caue I could do that without too much trouble. I don't know what I should do with the car though, I have a daily '86 camaro so I might gut the inside and turn it into a weekend car.
Old Jan 18, 2001 | 06:56 PM
Mike92's Avatar
It may be involved but uhh a cam is only 80bucks(summit brand) Aluminum Heads are $900 on up. Plus the flat tappet cam in the car now is probably worn because it's not nearly as tough as a roller cam. Some lobes are probably giving very little lift. A cam swap isn't the hardest thing in the world and if you have a daily driver, then it would be fun to tear down the other car for a weekend, maybe that's just me though .
Old Jan 18, 2001 | 07:40 PM
Agreed. now for a place to work on it.
PurelyPMD
May 5, 2016 04:57 PM
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
angel2794
Sep 8, 2015 06:22 PM
