? about v8 trans. in v8 motor swap from a v6 motor
I put a 305 H.O. in my camaro
and I have a Th 400 trans. but the drive
shaf,t and torque arm, trans. crossmermber
will not fit
what trans. do I need for the parts to work
thanks
C man
motor was a 2.8L v6 now it is
a 305 H.O. with headers,
403 heads and cam, intake
manifold a th400 trany.
will not fit
thanks
C man
Transmission: 4L80E/4L80E
Spohn makes the crossmember and torque arm mount you need. See their ad.
For the driveshaft, I hope you got the TH400 yoke with the transmission. If not, you'll have to go out and buy one. With everything mounted (best if this includes the torque arm) and the vehicle supported with the weight on all four wheels (or at least jack stands on the rear axle), put the yoke in fully and then pull it out 1". Measure from the middle of the yoke u-joint mount to the middle of the same on the differential yoke. Take the yoke and your current driveshaft to a driveshaft shop, tell them what you're putting it in and the measurements, and have them fabricate a driveshaft with the correct yoke & u-joints. It's not all that expensive (less than the crossmember & torque arm mount), and a properly manufactured and balanced driveshaft is a joy to drive.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
can I just buy a th700R trans will it work
or what our trans will work
C man
C man
Well, as you can see in my sig, I have a TH700 in an original V6 car. You'll need the shorter driveshaft, torque arm, and crossmember to accommodate the longer transmission (available from boneyards). The only issue with the '82 bodies is that the "frame" does not have the holes needed to mount the back two crossmember bolts. I drilled the holes to match, elongated a drain hole towards the back of the frame pieces, and put nuts/washers inside the frame for those two bolts. A bit ugly since I didn't dress up the holes I elongated, but otherwise no problem.
If you want the lockup torque convertor (assuming you don't have the ECM for the 305), you'll need to get a switch setup for that.
The other possibility is a TH350 (which is a lot like the original TH200 externally). You'll need a torque arm mount, available from Summit or Jegs, which is only on the order of $75.
what if a get a trans from a V8 camaro
will it just fit in
or will a TH 200 just bolt on
C man
[This message has been edited by 82camarov6 (edited January 24, 2001).]
will it just fit in
C man
If it is a 3-speed auto from an '82 or '83 V8 f-body, it will "bolt up". Any overdrive is going to cause you the troubles noted above.
The TH400 is a great tranny if you can live without the overdrive. Since you already have it, it is probably the one that would be the least expensive to make work, and the longest lasting for the money.
TX-SleeperC5
Sep 24, 2015 03:13 PM
