roller cam on a 305
Car: 1988 Mustang GT
Engine: 302
roller cam on a 305
Can I put a roller cam on my 1982 LG4 305? also any recommendations on size? i want good low and mid power but also its still gonna be a daily driver, i already have a edelbrock performer manifold and a edelbrock 600cfm carb...
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
roller cam wont fit unless you get a retro fit kit. go with a hydraulic flat tappet Xtreme energy 252 or somthing with new valve springs
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
13.24@104
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
then go with my cam.....Im warning you that this is a hearty cam for a 305, or a 350 for that matter. If you want a rough idle and have a 5 speed then I guess this will do it.
Transmission: 4L80E/4L80E
You've got conflicting desires here. In your original post, you said you wanted good low & midrange power but keep it a daily driver - no problem there. But then, you said you wanted a rough idle - not compatible with your original idea on any count. Your current manifold, carb, heads (and I assume stock exhaust) are not compatible with vortec's cam, either.
If you want the first part along with a rough idle, create a small vacuum leak on one intake manifold runner, and you'll get all your wishes.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, hi-flow cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Car: 4
Engine: 6
Transmission: 5
The one I'd recommend for going in a LG4 is the Comp XE262H flat-tappet. There's no point in putting $600 worth of roller stuff in that motor, basically it's a very low bang for the buck mod in that application. The 262 gives good power, and will work OK with the stock heads.
I take it you have already replaced the distributor with something appropriate too. If not, I'd do that immediately, before I'd do a cam swap.
Also, the weakest link in that engine is the exhaust, all the way from the heads to the street. You will get minimal benefit from any cam you put in there until all that garbage is gone. Get something like the TES for a L69 or L98, and the cat and cat-back for the same application; DON'T get stuff for the LG4 as it will be the same size as the little weenie head pipe and cat that are the problem in the first place.
ICON Motorsports
ICON Motorsports
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
