V6 to 305
Old Feb 17, 2001 | 11:25 PM
Ovrclck350's Avatar
V6 to 305
I have a donor 87 TPI Formula and a T350 Transmission in the back yard. My current vehicle is a 92 V6MPFI Firebird. What all am I going to have to yank off of the donor when I do the swap? The Formula is a standard transmission, and I'm keepin an automatic, so what would I do on the computer end? Could I just burn a prom? Also, what will i do for the speedometer if my T350 is cable driven? Isn't mine electronically controlled? Any light shed upon this subject will be a great help to me.
One more question...Will my radiator hold up to the 305?
See pics @ Billy's Firebird
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
98 or 99 Dodge Stratus (tough one, edged out at 40)
92 Camaro RS 305 TPI
97+ Honda somethin or another...modded....kept at my door the entire way
Close Calls
94 Grand Am 3.1 V6
92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
Old Feb 17, 2001 | 11:58 PM
87RS402's Avatar
The bellhousing patterns are different between the two engines, so you might want to rethink the keeping the auto part. You'll need the computer, wiring harness, and motor mounts for sure. I don't know about the other stuff. Isn't the rad from the donor car availible? I'd also check the rear end to see if it's a better unit than you have now.
If you swap the stick, you'll need the pedal and all hardware for it too.
Old Feb 18, 2001 | 12:40 AM
Ovrclck350's Avatar
Well, i decided to go w/ a 350 instead...Might as well now instead of later. Anything I'm going to have to buy in addition to what i already have, such as an intake?
I don't know if the radiator's available or not, my uncle wants the car for a race car, i want the TPI, puter and all that.....
I know the V6 and v8 tranny are different.... I have a Turbo 350 tranny in the backyard for the 8 to hook up to.
Old Feb 18, 2001 | 01:06 AM
87RS402's Avatar
Offhand the only other thing I can think of is a trans cooler, your rad doesn't have one and the donor car is a stick so I doubt it has one in it either.
Oh, You'll need a good supply of band-aids and beer
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
