Engine money on friday, what would *YOU* do??
Looking at just a touch under a grand.
I have-
~full 3" exhaust, headers, 4bolt 350 block, needing rebuild. double hump heads, extra stock intake, Qjet.
~running LG4
I'm thinking summit rebuild kit for the 350, rebuild heads. I'm looking for a mild-strong motor, maybe around 290-310hp/330-340Tq. Shopping list is going to include a X268cam, and I'm planning on doing as much assembly as I can myself. I'm planning on doing the porting on the heads myself too. What would you guys do??
Matt86Z
~Check out my Thirdgen~
...This Ain't No Speedway!...
I have-
~running LG4
Matt86Z
Transmission: 4L80E/4L80E
Sounds pretty good, but doubt you'll make it for under $1k, especially if you're talking rebore and pistons.
Only thing I'd add is screw-in rocker studs (not sure if double humps had press or screw-in), and valve springs to match the cam. Weiand Action + would be nice, but would probably bust the budget for sure.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Actually, I just found out they are 291's! Happy about that, better heads than I thought. 64CC, 202/160's.
Seems they have a whack of meat on them that could be ported nicely too!
Matt86Z
Matt86Z
Terrell351
Jun 13, 2021 01:13 PM
