New Pistons with stock crank & rods??
Car: 1986 Camaro Z28
Engine: 305 Carb
ok I have gone from just droping the L98 in my camaro TPI and all, to going with a carb intake and new cam setup, to head work, and now thinking since the engine will be that far down go ahead and freshin up the bottme end.
My question is would the stock crank and rods be good to reuse with some new pistons on them? and if so what are a good set of piston to use?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Yes, the stock crank and rods are fine to use with new pistons.
Typically, new pistons aren't required unless you need to do a clean-up overbore on the cylinder walls, or you need to change the compression ratio with dished or domed pistons to make up for cylinder head combustion chamber size.
Since you're planning on using the L98 heads, the only viable reason is #1.
With a light glaze breaking of the cylinder walls, assuming no excessive wear or scoring, you can reuse the pistons with new rings.
Engine: 305 Carb
Re: New Pistons with stock crank & rods??
Well I think I will just use all the stock bottom end and go with a good clean, rings, and bearings.
Car: 91 Firebird
Engine: 3.1
that is what i am about to do also. I just picked up an lt1 and all the cylanders are good except for one. so i think i am going to bore it 30 over and just put new pistons in
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
However you go just don't forget the balancing end of it
Later
Later
Engine: LS1/LQ4
Unnecessary with a mild build, especially when reusing the original pistons.
In almost 40 years of putting engines together, I've balanced a grand total of one engine.
Engine: 305 Carb
After talking with my engine guy. I am going to pull the top end down, and then take the bottom end and heads to him to look at. I am going to have the heads done all the way. Now for the bottom end , if everything is in good shape he is going to just take it all down, and put new bearings in and just use the stock crank, rods, and pistons.
ambainb
04-25-2016 09:21 PM
LT1Formula
08-20-2015 09:36 PM
