STOCK GAUGE QUESTION- will they work after engine swap?
Old Apr 27, 2001 | 07:47 AM
Tom Batts's Avatar
Old Apr 28, 2001 | 07:58 PM
ede's Avatar
ede
just hook them back up, most likely the senders will go back just like thay came off the other engine.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 28, 2001 | 08:18 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
question what year is your car? IF it is an 87 and up bird and you are switching to a carb then no unless you leave the comp hooked up. same thing for 90 and up Camaro's. If you leave the fuel injection everything should be ok.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Old Apr 29, 2001 | 09:10 AM
Tom Batts's Avatar
Old Apr 29, 2001 | 12:33 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
what do you mean 87 and up bird? I am swapping my V6 out for a built 350. the gauges wont work? mine is 89.
Wide Open Till You See God...Then Brake
Old Apr 30, 2001 | 08:33 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
87 and up is computer controlled gauges. SO as long as the comp is still hooked up they should work. 86 is not comp controlled
future mods:
Old May 1, 2001 | 06:57 PM
Tom Batts's Avatar
Old May 2, 2001 | 12:06 PM
Black 84 Z's Avatar
Car: 1984 Z28
Engine: 350ci
Axle/Gears: 3.73 12 bolt
Whew, you guys were scaring me for a minute. I just did the 305 to 350 and had to leave the computer on it till i could buy all the other parts (carb, manifold, dist). I was concerned that my gauges would not work without the computer when i finish the computer delete option!!
DG
1984 Z28 LG4/A4
Mods: are you kidding? They cost money.
Powered by Eclipse, Kicker, Rockford Fosgate, JL Audio, and MB Quart.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
