What fan will fit my car?
Old May 3, 2001 | 11:59 AM
ChrisFirebird's Avatar
I have a 1985 Firebird that had a 2.8L motor but I now have a 350 motor in it. The fan from the 350 motor is too high and sticks up out of the radiator shroud about 2 1/2 inches and its a bit dangerous. I was wondering if a V6 fan will fit and be smaller so it doesn't stick up so high.
Thank You.
Old May 3, 2001 | 02:25 PM
MikeS's Avatar
Did you switch your radiator shroud to one from a V8 car with a belt driven fan? If not, make sure you do. Since small blocks were offered factory in your car, whatever you find on a junkyard V8 thirdgen will fit yours. After I swapped the 2.8 in my 84 Camaro for a 350 I used the belt driven fan and fan shroud from a wrecked firebird with a 305. That setup ended up not cooling well enough while sitting in traffic, so I switched to the single electric fan setup from a thirdgen Z28. Hope some of this info helps. Let me know if there is anything else you need to know.
Mike
Old May 3, 2001 | 03:29 PM
MAXGTA2002's Avatar
I would use a electric fan also, whether or not it was a single or a double.
Don
RazorN8
Jan 7, 2022 11:44 AM
customblackbird
Aug 15, 2021 10:16 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Leggman1
Aug 6, 2015 04:15 AM
