305 TBI to 350 TPI
Old Nov 23, 2009 | 09:29 AM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
305 TBI to 350 TPI
I have a 305 tbi v8 and I wanted to switch it to a 350 TPI, what do I need to change? and do I need to change the fuel delivery? sorry if its a repeat question
tim
Old Nov 23, 2009 | 03:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need to change everything that's different between TBI and TPI.
That includes the entire induction system, upper radiator and heater hoses, throttle cables, air cleaner system, in-tank electric fuel pump, flexible fuel lines, ECM harness, ECM, knock sensor (and module, depending upon the year of the TPI). TPI also had dual radiator fans (most years).
Have you located a 350 TPI? If so, how complete is it?
Old Nov 24, 2009 | 02:15 AM
Car: 1990 camaro rs
Engine: 305 tbi
Re: 305 TBI to 350 TPI
well I was thinkin of grabbin one from hawksthirdgenparts b'cause their close but one of my friends who has 30+ years of experience workin on cars said it might be easier to get a crate enginethats the same size or bigger, so I dont know
Old Nov 24, 2009 | 02:02 PM
five7kid's Avatar
Hawks will treat you right.
As for a crate engine, depends. You aren't going to get a TPI set-up with a crate engine. If you stay with TBI on a crate engine, the TBI system is going to need upgrades.
Old Nov 24, 2009 | 05:07 PM
Car: 1990 camaro rs
Engine: 305 tbi
Would it be easier to stay with a tbi setup and a crate engine or should
i go carbed, which is easier?
Old Nov 24, 2009 | 05:19 PM
five7kid's Avatar
What are you after? More street legal power?
A 350 TBI can accomplish that. A Hawks 350 TPI pull-out would probably be a lot easier to do (and perhaps less expensive).
There isn't a legal carb that you can install in a 1990 chassis.
Old Dec 13, 2009 | 02:06 PM
fcukit33's Avatar
Car: 92 camaro rs
Engine: 305tbi
im in the same boat..i posted something up in the TPI section but got no responces
five7kid what do u mean about the fuel lines having to b changed...are you talking about the the hard lines that run from the tank to the engine bay or just the engine bay to engine?
Old Dec 14, 2009 | 01:35 PM
five7kid's Avatar
The soft lines, chassis to engine.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92purpz28
Aug 11, 2015 02:30 PM
