Need Help Picking Out Engine Project
Old May 3, 2001 | 02:30 PM
88 Camaro SC's Avatar
Car: 99 Trans Am
I'm starting a 383 project build-up. At first, I thought the set-up I was going to do would consist of Trick Flow heads, an Xtreme Energy Cam, Edelbrock Performer RPM, Holley 750, and the rest. BUT... now I heard about that Edelbrock set-up, with 420 horse. Their own heads, cam, intake, and carb. Which would be better? I really don't have an estimate for my original idea, so I don't know how that power would compare with Edelbrocks 420 horse. Any help is greatly appreciated.
Nate
1988 Camaro Sport Coupe
  • Custom Interior
  • K&N Air Filter
  • Shift Improver Kit
Homepage: www.rsdragster.cz28.comp
Old May 3, 2001 | 07:02 PM
Brian92RS's Avatar
Can't give you much advice on the buildup idea... But I can suggest you go with a GMPP crate motor. You can get a ZZ430 clone for about $4,300. That is a fully assembled (comes with distributor and 5 quarts of oil!) time tested power plant that will give you 430 horsepower right out of the box and COMES WITH A WARRANTY!
You'll spend much more than that building your own. Then you have to worry about matching up all the components. Just an idea good luck on whatever you decide to do!
Old May 4, 2001 | 02:34 PM
Car: 99 Trans Am
<font face="Verdana, Arial" size="2">Originally posted by Brian92RS:
You'll spend much more than that building your own</font>
Actually, I've already done all the research on it, and I can put a 400+ horse one together for around $2,500. That's mainly because I have some of the more expensive parts already.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
