Knock Sensor differences 86 305 TPI to 86 350 TPI?
Old May 18, 2001 | 07:01 AM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
I really need to know if there is actually a difference cmon guys please. the dealership and the parts store says there isn't. Can anybody prove it to me?
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
1.74 60 ft 12.84@107.75 on the bottle.
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old May 18, 2001 | 10:52 AM
camarocowboy's Avatar
I will try to help<i just swapped a 305 tpi for a 350.I used every part (electical) from my 305 eccept injectors and temp sensor and all hokked up fine.The part #'s will be same for 305 and 350 in most cases.I checked the MAF,(same), fuel pressure regulator,(same)TPS,(same)IAC,(same)ETC.I am having some problems but not related to stock swap my problems are from aftermarket additions.If all you want to know is if they are the same #,they are cubic inches plays no part in it's function.Hope this helps some.
Old May 18, 2001 | 10:53 AM
I will try to help,i just swapped a 305 tpi for a 350.I used every part (electical) from my 305 eccept injectors and temp sensor and all hokked up fine.The part #'s will be same for 305 and 350 in most cases.I checked the MAF,(same), fuel pressure regulator,(same)TPS,(same)IAC,(same)ETC.I am having some problems but not related to stock swap my problems are from aftermarket additions.If all you want to know is if they are the same #,they are cubic inches plays no part in it's function.Hope this helps some.
Old May 19, 2001 | 05:18 AM
zz4mula's Avatar
Car: FORMULA 350
Engine: ZZ4
the dealership employee is a putz if you told him you did an engine swap. Since the 305 was only offered on a regular basis in the f-body in 1986, the parts catalog would say "all V8's use this number" so to speak. Go up a year to 1987, and I bet he has two part numbers, one for 305 and one for 350.
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
gwade12
Aug 8, 2015 08:17 AM
