305 and 350 TPI Knock Sensor
Old May 15, 2001 | 12:31 PM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
Can anyone tell me if they are actually different? I have an 86 305 and I am dropping an 86 350 TPI in its place. Are they different? Does anyone know the part number for the 2?
thanks
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
1.74 60 ft 12.84@107.75 on the bottle.
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old May 16, 2001 | 08:08 PM
gwman's Avatar
I Changed from a 305 to 350 in my 91RS and was wondering the same thing. Nobody could give me the part numbers so I left the 305 knock sensor in. Im am not sure if it is causing any problems to the engine, but I am having tempreture problems. Not really sure if this has anything to do with the knock sensor though. I am thinking about changing it but I dont know which one to put in .
Old May 17, 2001 | 07:44 AM
KustomIroc's Avatar
Engine: 383 Stroker
I cross referenced the numbers and they seem to come up with the same numbers both at the GM dealer and at the local parts stores. So who knows? I would like to know if anybody knows for sure.
What size thermostat are you running? The knock sensor wouldn't/shouldn't have anything to do with heating problems.
Jamie James
1986 Iroc-Z 305 TPI
My IROC:
Old May 17, 2001 | 11:03 PM
rsilver's Avatar
Yes the knock sensors are different. Apparently they send a different signal to the computer. there have been some posts on this so you can learn more by checking the archives. the 350 knock sensor that I used is part # 10456288. Comes out of a 89 350 cop car but is the same as many other 350 applications. I understand that the ESC module should be changed too. Prt number 16128261. Good luck..........bob
Old May 18, 2001 | 02:26 AM
silverstreakII's Avatar
<font face="Verdana, Arial" size="2">Originally posted by gwman:
I Changed from a 305 to 350 in my 91RS and was wondering the same thing. Nobody could give me the part numbers so I left the 305 knock sensor in. Im am not sure if it is causing any problems to the engine, but I am having tempreture problems. Not really sure if this has anything to do with the knock sensor though. I am thinking about changing it but I dont know which one to put in .</font>
check your airdam under the car and the fans (2), and of course the tstat, oh and if that doesnt work becool sells an aluminum radiator for it, 700 bucks or so though, but itll keep ya cool
Old May 19, 2001 | 02:58 AM
quick91z28's Avatar
There is a difference in knock sensors R Silver is right
Old May 22, 2001 | 11:13 AM
KustomIroc's Avatar
Engine: 383 Stroker
Due to time constraints I did not change the knock sensor or the harmonic balancer and everything seems to be running fine with 1000 kms on the engine so far.
Jamie James
1986 Iroc-Z 305 TPI
My IROC:
Jake_92RS
Jan 28, 2020 10:37 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
