BBC & T5 tranny
Old Jun 7, 2001 | 05:16 PM
Camaroman's Avatar
BBC & T5 tranny
I have a '72-'78 454ci motor...out of a truck
not sure what year it is but...
for moving around purposes...I'm gonna take my T5 and bolt it together...
Can I use my stock flywheel? (from an '84 Z28 L69)
Anything else I would need or should concider?
I know that this tranny is not very strong so dont worry about that.
Old Jun 7, 2001 | 06:26 PM
JPrevost's Avatar
Car: 91 Red Sled
That tranny isn't going to last a week. The T5 is the weakest tranny from GM. They didn't even trust it behind a simple 350 and lots of guys here have had problems. HP doesn't kill tranny, it's the torque. If you build a BBC to make less than 300 ft-lbs then MAYBE it will last you a little longer. Good luck, just wanted to point out that it just wouldn't be worth it. It's going to be tricky getting the BBC in and won't be cheap, then the tranny is going to be your weakest link . What are you going to do if it breaks in a couple of weeks?
, Jon (350 TBI!)
91 Red My website
Old Jun 7, 2001 | 06:41 PM
jms's Avatar
jms
The 454 uses an externally balanced flywheel. Your flywheel is for an internally balanced engine. Physically it will bolt up and will work on the engine but is totally not balanced for the big block.
If you put it on JUST TO MOVE THE CAR AROUND, and don't run the engine very much, you might get away with no problems.
You also may run into a starter motor problem. If I remember correctly, the big block has both starter patterns. Check this before putting the engine in.
REMEMBER, the flywheel will fit but don't run the engine very much.
jms
Old Jun 7, 2001 | 06:43 PM
87RS402's Avatar
For moving it around only, it will work. If it will bolt up is different. I know the 454 is externally balanced but I don't know if the flywheel is weighted likw on the 400SB.
EDIT: jms, you beat me to it.
[This message has been edited by 87RS402 (edited June 07, 2001).]
Old Jun 7, 2001 | 07:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Flywheel weighting is identical to the 400, just like flex plates. For my 400 I had a L69 flywheel "unbalanced" to the 400/454 spec, which was easy to do by drilling about 20 7/16" holes around one half of it. Of course I didn't just take a drill to it myself, I had a balance shop do it, but the balancing itself isn't very high-tech or anything.
The others are right, your 84 T-5 won't live very long behind a big block, even a weak one like that, if you drive it very enthusiastically. I have had a great deal of trouble with my T-5 over the years.
You will need to drill the inboard starter bolt hole in your 454 block. Use a long drill bit, and the starter nosepiece as a guide.
ICON Motorsports
Old Jun 8, 2001 | 01:02 AM
CrazyRob75's Avatar
Why the hell would he have to drill the block? Use your SBC starter and change the snout to the staggered mounting bolt pattern. Putting a BBC in is not that big a deal. It just takes a little patience and NOT a whole lot of modifying (unless your putting in Hookers)
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, 275/60/15 Hoosier Quicktimes and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
Old Jun 8, 2001 | 09:00 AM
Mark W. Winning's Avatar
Pull 4 plug wires when you need to move the car! LOL. I can just see the t-5 start shaking when you fire the BBC!
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Caden
Aug 14, 2010 07:31 PM
Tbi-MAX
Jul 9, 2008 12:57 PM
IHI
Nov 25, 2007 10:56 AM
ZAKS62
Oct 29, 2007 11:05 AM
nbn792
Mar 22, 2002 10:16 PM
