305TPI to 350 TPI
Old Jun 25, 2001 | 01:41 AM
PurpleHazeZ28's Avatar
305TPI to 350 TPI
Hey everyone hope some people can make sugestions.
I have a 92 z28 that has some engines damage due to lack of oil so I figured I would put a 350 in there.
I am wanting suggestions on some engines to use, I want to keep it TPI so take this into consideration.
I was going with the ZZ4 but I have a few buddies that say everyone they know that has done this swap with TPI can not get it tuned and running right. Can anyone shed light on this?
I was also considering GMs HO 350. so if anyone can help with this Please do I can't make a decision cause I want it bad *** but I want it done with no problems.
thanks
Old Jun 25, 2001 | 01:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Forget the 350HO until somebody comes out with a viable TPI manifold to mount to Vortec heads.
The ZZ4 can be done - have a buddy that did. But, with all the other things he did, his experience isn't of much value to you if you simply want to bolt a ZZ4 under your TPI.
The ZZ4 does not have exhaust cross-over passages in the head, so the EGR has to be fed to the intake from the exhaust manifold/header.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Old Jun 26, 2001 | 01:55 AM
Ok so what engine do you suggest?????
Old Jun 26, 2001 | 03:38 PM
stevenmh's Avatar
http://www.golensengineservice.com/
1989 Formula WS6 M5
SLP cold air induction, K&N filter, TPIS modified MAF, TPIS 52mm TB w/ airfoil, Random Tech cats, SLP cat-back, TPIS AFPR, March underdrive pulley, Accel 300+ coil & 8.8mm wires, Bosch Platinum+4 plugs, Hypertech 160°F t-stat & fan switch, Hypertech Streetrunner chip, Centerforce dual-friction clutch, PST front suspension kit, PowerStop cross-drilled rotors, Porterfield Carbon Kevlar pads, Russell SS brake lines, Firehawk SZ50 EP P255/50ZR16.
G-Tech Pro measurements:
0-60 mph: 6.0 sec
212 RWHP
1/8 mile results: 9.74 sec @ 74.5 mph; 0-60 ft @ 2.35 sec; +0.46 reaction
2001 Trans Am WS6 A4
Stock
More info at website:
www.fbody.com/members/stevenmh
Old Jun 26, 2001 | 03:59 PM
91-ZZ4-Z28's Avatar
The Gloen motors make good power so they say but the are 2 bolt main ironhead ironcrank unless you want to pay alot extera. The ZZ4 with a HOT cam and 1.6 rockers will make big power and will last, 4 bolt main aluminum head forged steel crank.
Old Jun 26, 2001 | 07:19 PM
five7kid's Avatar
If you are willing to change the intake base & runners, injectors (you didn't say which engine you have now, may we presume 305?), perhaps TB, and go with a custom chip, the ZZ4 would make a great TPI engine. You just need to pay attention to the details as you go along.
Or, get a ZZ4 shortblock and put your choice of aftermarket heads on it to match whatever you do with the TPI. Remember, it's the "package" that makes an engine run well. That means the cam, heads, intake, runners, injectors and programing all have to be chosen to work together.
Have the people "known" to have done this swap done something about the EGR? If they just left it blanked off and didn't redo the PROM, there's a problem right there. Fuel pressure? Adjustable makes it possible to feed the engine what it needs. Did they stick with the stock runners, plenum, base, TB? Mismatched with the ZZ4 cam. Etc., etc., etc.
Old Jun 27, 2001 | 01:25 AM
I currwntly have the 305 TPI which has some damage to it so i figured go with the 350....
so is everyone saying go with the zz4 instead of the HO GM 350? I know its not as bad *** as the zz4 but its an option for $1000 less.
Also any other suggestions????
Old Jun 27, 2001 | 07:11 AM
91-ZZ4-Z28's Avatar
What I have done is turn the EGR off in the PROM and left it in place. For two reasons one at inspection time if it is there they have on way to know if it works or not, and that way you dont have to buy a block off.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
Old Jun 27, 2001 | 09:34 AM
ImportsRsloths's Avatar
91ZZ4
How do you turn the EGR off in the Prom??
Old Jun 27, 2001 | 10:31 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
<font face="Verdana, Arial" size="2">Originally posted by 91-ZZ4-Z28:
</font>
That's funny, LOL. There is a way to test if the EGR works, and it is a pass or fail situation only. By applying vacuum to the EGR when the vehicle is in idle, the engine should mis-fire or stall. If this does not happen, by emissions laws, you fail. Period. That is how an EGR is tested.
George P. Lara
1984 Z28
SCCA, SCFB, SC3GFB
Old Jun 27, 2001 | 12:43 PM
91-ZZ4-Z28's Avatar
If you want infomation on PROM programing you can check the forum there is a bunch of info on the hardware and software you need to burn your own chip
In North Carolina EGR is a visual inspection only unless you fail emmisions test and it will not keep you from passing that. If they actualy test the EGR in you state then you will need to get the tube from an L98 vette setup.
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
