Hood Clearance???
Old Jul 1, 2001 | 05:29 PM
The_OutCast's Avatar
Hood Clearance???
I have a 91 Formula and Im gonna swap out the 305 for a ZZ4.
Am I gonna have enough clearance with the stock hood?
Old Jul 1, 2001 | 06:32 PM
Tas's Avatar
Tas
depends on your intake and air cleaner choices.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 1, 2001 | 07:42 PM
firbird's Avatar
i do not know i am have the same question do you think this will fit under my hood it looks way too tall. http://firbirdgta.tripod.com/cars/id8.html
its a 350 with preformer rpm intakemanifold and a holley tbi
oh yea i have a 92 firebird
Old Jul 1, 2001 | 11:27 PM
I want to use the performer RPM.
Old Jul 2, 2001 | 12:08 AM
firbird's Avatar
carb or tbi?
Old Jul 2, 2001 | 07:22 PM
I'm gonna go with a carb and drop the tbi.
Old Jul 2, 2001 | 10:44 PM
sb406camaro86's Avatar
Car: chevy s10,1986camaro
Engine: 406sbc
Transmission: 350turbo
u should have enough clearance if u use a drop base air cleaner assembly, it worked in my camaro with a rpm manifold and holley carb, unless the camaro has more hood clearance than the firebird, if it does i don't think it will work cause mine was just able to clear.
Old Jul 4, 2001 | 03:59 AM
ta84-355's Avatar
Car: Trans Am -84
Engine: 355, Twin Turbo
Axle/Gears: 3.73 open
I've got a TA-84 with the bulge on the hood. I installed a 355 with Performer RPM intake and a 13x3 inch drop based Mr. Gasket chrome air-cleaner. When I closed the hood it touched the ram-air system. I removed the plastic stuff and also the hood insulation and carefully bent the sheetmetall flange that the ram-air system was attached too, just about 1/4 inch or so. It fits and look great.
I was able to close the hood even with the ram-air system in place but the torque from the new engine makes it hit the ramair if you don't remove it.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
