Headers & y-pipe to use 93 LT1/89RS Swap?
Old Jul 5, 2001 | 07:26 PM
multi-tasking's Avatar
Hopefully, the subject speaks for itself....
I am in the process of swapping an LT1 into my 89 RS. My RS was/is a V6 (yes there is lots of pain with this swap., but I am sucking it up - so, don't cry for me).
I noticed on a friend's car which had Block Hugger headers there is not a lot of room on the drivers side. In fact, that header is actually touching and being worn away by the steering shaft knuckle. That is not at all what I want! I need someone to tell me how they found a solution to this problem. Which header/y-pipe combination they used and if their solution was economical.
Also, I want to keep all of my emissions stuff. So the header must include the smog pump and O2 sensors…..
What I am hoping to avoid is beating, banging and unnecessary welding. I need help in finding a solution that is geared toward a nice set-up that is affordable, but emissions legal.
m-t
Old Jul 6, 2001 | 12:57 PM
I will take any suggestions you good people have to offer....
HELP!!!!!!!!
Old Jul 6, 2001 | 03:48 PM
mat89RS's Avatar
hedmans hookers headers are just the right size on my car .
89 Camaro RS Stock as a women with white panties
LT1 IS COMMING SOON.
Old Jul 6, 2001 | 06:37 PM
Thanks Matt. Got to looking around today on and found it.... Hedman has a parts number "68481" that their tech support say is a direct fit.... I will order it Monday.
Again...Thanks
m-t
Old Jul 7, 2001 | 12:18 PM
TexasLT1's Avatar
Car: '92 RS
be sure to order two weld-on 02 sensor bungs because the heddmans dont come with them, you may only need one, I know that mine has two 02 sensors
Old Jul 8, 2001 | 09:19 AM
<font face="Verdana, Arial" size="2">Originally posted by TexasLT1:
be sure to order two weld-on 02 sensor bungs because the heddmans dont come with them, you may only need one, I know that mine has two 02 sensors</font>
What is a OS sensor bung? I talked to a guy from Hedman and he told me I needed to order a kit., but I left the part number in the office....
Old Jul 8, 2001 | 02:25 PM
TexasLT1's Avatar
Car: '92 RS
I would order everything from Jegs, it might end up being a little cheaper, I think I got headers and y-pipe for like $209. the sensor bung is basically a round nut with threads on the inside that you weld to the headers or y-pipe and then drill out the center, well, vice versa, and it allows you to screw in your O2 sensor, they are only like a dollar or two, but you need two of them , one for each side
Old Jul 8, 2001 | 02:54 PM
thanks... I was hoping not to have to weld, beat, bang or any of the stuff... but., head held high., wallet in hand., we carry on...
Old Jul 11, 2001 | 09:28 PM
89camaro's Avatar
I am doing the same swap. I just installed edelbrock headers for a 94-95 model. they hooked up good. I should know tomorrow if the y pipe hooks up good. It has the profissions for the o2 sensors allready. The exhaust ports are D shaped to match the heads.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1984HO
Mar 19, 2021 11:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
