350 TPI swap into 92 RS
Old Jul 31, 2001 | 04:47 PM
Gen X Mar0's Avatar
Car: 1991 Z28
Engine: 5.7 Stealth Ram
Transmission: Pro-Built 700R4
I bought a 350 tpi motor from thirdgenresource out of a 88 GTA....what all is gonna have to be changed to make it work....so far all i can think of is bigger fuel lines and fuel pump..the engine has vss so thats not an issue thank God...but what else will come into play that will cost me more $$$$$$$$$$$$$!!!! thanks
p.s. my car had the 305 tbi
Old Jul 31, 2001 | 05:23 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
my friend, you are going to need alot of HARD LIQUOR cuz youre gonna need to change the ENTIRE wiring harness!!!!!!!!..........yes every single thing that is hooked to the harness need the harness to be pulled from it and have the new one put on..........everthing from the rear lights to the radio and interior lights...........hope i made your day better
Old Jul 31, 2001 | 05:37 PM
multi-tasking's Avatar
Try these...they should get you off to a good start.
www.thirdgen.org/messgboard/Forum14/HTML/000764.html
www.thirdgen.org/messgboard/Forum14/HTML/001401.html
www.thirdgen.org/newdesign/faq/thirdgen.shtml
350.streetracing.org/lt1.htm
www.hpsalvage.com
m-t
[This message has been edited by multi-tasking (edited July 31, 2001).]
Old Aug 1, 2001 | 11:24 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">everthing from the rear lights to the radio and interior lights...........hope i made your day better [/B]</font>
are you on crack or some thing?the only wire harness you'll need to change is the engine harness.off the top of my head you'll need
t.v. cable
accelerator cable
cruize control cable(i'm getting rid of mine)
wire harness
ECM w/chip
fuel pump relay
maf relay
maf burnoff relay
you'll need to relocat the battery(i'm moving mine to the back)
fuel pump
if you have a 90 or newer f-body you wont have to replace your hard fuel lines.in 90 gm put a 3/8 fuel line in all of there V8 f-bodys.os you should only need to run a line from the fuel rails to the hard lines on the frame.
if you have any ?'s e-mail me at tonysams72@yahoo.com
for pics of my motor check out streetdawgracing
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
[This message has been edited by 91banditt2 (edited August 01, 2001).]
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
