6.6 liter tpi
Old Aug 7, 2001 | 04:33 PM
formula5's Avatar
6.6 liter tpi
How much power could a lighly modified 400 tpi get.I'm thinking a little over 300hp and a little under 400 ftlb of torque.
Old Aug 7, 2001 | 05:11 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Yeah 300hp at 3000rpm, and 400ftlb at 800rpm.
Joshua Johnston
1991 Z-28
Flowmaster
K&N
305 / 5spd. (Temporary)
Soon to have:
350, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, T&R Motorsports custom air intake
Old Aug 7, 2001 | 05:29 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
At 300 Hp you'll be making more like 500 ft-lb of torque. A TPI strapped on a 400 is like using a 2-barrel carb on a built 454.
Old Aug 7, 2001 | 11:08 PM
formula5's Avatar
So your both saying that i would'nt go into the high 12s or low 13s.It does have 30lb hour injectors 3:42 gears and ported plunum,accel coil & wires and k&n filter.
Old Aug 7, 2001 | 11:14 PM
formula5's Avatar
From what i understand the 400 chevy by nature isnt a rev king.Tpi intake systems are designed for under 5000 rpm so whats the problem?
Old Aug 7, 2001 | 11:19 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
What they are saying is that the stock TPI, or even a modded TPI will not flow enough to feed a 400ci engine. I have already been through this junk, and have decided to go with the Accell SuperRam system. It makes power way beyond the range of the stock TPI. Why would you want 400ci and only make 300hp with it? If that is all you are looking for, swap in a 350 and do some work to your TPI, with a cam and heads, you should be around 300hp. If you want to build a 400, you are going to have to spend more money to get all the power out of it that is possible. There are many guys out there with SuperRammed 406's making in excess of 400hp at the rear wheels, and I am soon to be one of them
Old Aug 7, 2001 | 11:56 PM
formula5's Avatar
Thats the thing,I dont wan't to extract all the power from the 400.The goal is low 13s or a little better,fair gas milage and a smooth idle.A 350 w/ hi flow intake and cam will have to work harder to achive the same power.Put the same cam and intake on a 400 and it will make more power.That's sidestepping the issue though.The true reason for the 400 is the heritage of 6.6 liter and then blend it with multi port injection.Besides I have this project finished as of monday.It feels very quick but have'nt took it to gateway yet.
Old Aug 8, 2001 | 01:28 AM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I like mine.
Dan
87 IROC-Z, 6.7 $uperram & cam, Eagle 5.7" rods, Dart 200cc Iron Eagle heads, auto w/ BTE 3000stall lockup, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" headers, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback.
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear - FOR SALE
Old Aug 8, 2001 | 01:39 AM
formula5's Avatar
Is that a 327?
Old Aug 8, 2001 | 08:45 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by formula5:
Is that a 327?</font>
No Irocz has a 6.7, as displayed in his sig.
Old Aug 8, 2001 | 10:12 AM
formula5's Avatar
Iwas refering to the second car in his sig.What is a 6.7 ,a 400 bored 30 over?What is the track time for that big boy?
stalkier
Dec 6, 2015 11:25 PM
dyeager535
Aug 28, 2015 08:10 AM
Thornburg
Aug 27, 2015 08:28 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
