305 tpi to 350 tpi (hopefully)
Car: '86 Camaro Z28
Engine: 350 Tpi
Transmission: TH700R4
Axle/Gears: Factory
i have a 86 carmaro z28 with tpi i am going to take the 350 out of my g-20 van it has a 350 tbi in it what do i need to change or replace to make this work
Car: '86 Camaro Z28
Engine: 350 Tpi
Axle/Gears: Factory
Re: 305 tpi to 350 tpi (hopefully)
i know i need to change the fuel injectors and the fuel pressure regulator but what else do i need to change the whole computer
Car: 85 vette
Engine: 427 SHP block,AFR 210,MiniRam
Transmission: TKO 600
Axle/Gears: 3:07
Car: '86 Camaro Z28
Engine: 350 Tpi
Axle/Gears: Factory
so with my 86 do i need to change the prom and does anybody know where i can have my prom set for the 19lb injectors
Sanjay
Aug 12, 2015 03:41 PM
