'86 2.8 for a '88 Blazer 2.8???
My '86 2.8L died, I have a lead on a '88 Blazer 2.8L. What should I like for in this swap. Does it have the same injection (MPI)? Will the accessories bolt in? Or should I just use it for it's short block? I'm looking for a quick swap (not looking for power). If this is not a good swap then what's a good choice?
Transmission: 4L80E/4L80E
As I understand it, the S10 engine had the oil filter in a different location than the Camaro/Firebird, so if you use an engine from the trucks, you'll have to use an oil filter relocation kit. Take a good look at the oil pans as well, as they also may be different (not sure about that one).
Other than that, you should take your accessories off of your engine, including the induction, and put them on the truck engine.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
