Long block 350 for around 1k?
Old Aug 19, 2001 | 12:24 AM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
Is it possible to get a quality 350 longblock to replace my 305 with a blown piston for around(to under??) $1000? I know I can get a Recon for $800, and I dont want to start that whole "Only GM goodwrench engines work" debate, partially because it could not be true, and partially because some of it is. Emissions legality is essential(tree hugging bastards) unfortunatly, so does anyone have any good stories to report? The engine will be supercharged like the 305 before it, so it would be nice to find decent power with mild compression(9.5:1 or under).
Old Aug 20, 2001 | 09:12 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
over your $1000 marker but http://www.sdpc2000.com/cart.asp?act...id=128&pid=105 has nice new 350 engine. or you could go with a L98 short block http://www.sdpc2000.com/cart.asp?act...id=514&pid=620 and put some world class sportman heads on it and make good power before the super charger and A LOT with the supercharger.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
<p><img border="0" src="http://www.bharris.org/images/smcamconv.jpg" width="200" height="73"></p>
Old Aug 21, 2001 | 05:07 PM
nebulous's Avatar
Seems like thats the only chevy engine reseller that anyone here endorses. Is Scoggin Dickey really that much better than anyone else. Prices seem pretty high for the most part. Checking those now....
Old Aug 21, 2001 | 05:21 PM
nebulous's Avatar
hmm maybe I should eat my words. That first engine looks very good, and these are the first people that I have talked to that I actually liked. Anyone else here had good results with that one?
Old Aug 22, 2001 | 09:42 AM
you can also try http://www.paceparts.com/ they were cheaper on the particular engine that I wanted.
** Added so far **
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
MoJoe
Sep 24, 2015 09:12 PM
fbirdroller
Sep 2, 2015 10:27 PM
