SAD SAD day ... need advice
Well i was driving on the Freeway in my camaro doing at the most 90 here and there but then i get of and about two miles later my eninge starts to knock its a 350 the car also ddnt start up after i shut it off i had to get a jump to start anyone know what might of happend and should i fix the motor
or buy a new ... plus where is the best place to get good motors?
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: SAD SAD day ... need advice
well, how about giving us a bit more details? What kind of a 350 is it? From factory? aftermarket? tpi, tbi, carb? What year car? If efi, any codes being thrown?....
Car: 1987 Trans Am
ok. 350's never came in TBI format in 3rd gens, so its probably from another car or aftermarket, (which I'm guessing since the block is blue, another thing that never occurred from the factory). Probably what they did is get a 350 block and keep the tbi stuff from the original 305. What is the engine doing now? Does it turn on only when jump started? or does it not run at all or crank?
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Yes, thats TBI (Throttle body injection). Really hope that isn't a 305 hiding in there. Anyways, is it knocking under load or just while idling? If it's knocking while idling, it may be time to dismantle it and rebuild.
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
sounds like its time to take it apart and rebuild it...
try not to run it since is could be a spun bearing you can still save the crank.. i would pull it apart and see what its insides look like and make sure its a 350 before you rebuild.
Car: 1987 Trans Am
around what part of the engine is the knocking coming from? top (intake), bottom (block), or sides (heads)...?
Car: 91 Formula ex-1/4 mi. car
Engine: LS1/LS6 SLP maf K&N cai 3" exh
Transmission: built 700R4 w/ 10" HUGHES 3300stall
Axle/Gears: MOSER AXLES, 3.73 w/ posi
yep, looks like a 305 to me you really should replace or rebiuld if you can.
i have a fully forged 383 stroker kit for sale, cheap! if your gonna do it, might as well do it right!!!!
Car: 92 Formula 350
Transmission: TH700R4
Axle/Gears: 3.23 posi
I thought I had a knocking coming form my car once. Knocked on idle, sped up as I gave it gas and everything. I thought I was screwed, took the car off the road and everything.
Turned out to be the plastic torque converter cover that had come loose and was hitting the torque converter and flexplate lol
what would i need to put this motor in mine?http://detroit.craigslist.org/mcb/cto/1558337024.html
A carb setup or a good bit of tuning. That will not play nicely with TBI
Id suggest a different motor. How you build a 383 with a stock 350 crank is beyond me
the motor 383 stroker around 500hp nothing on this motor is stock olny the crank
I have a stroked 385 that possibly for sale.its a 350 bored 40 over with a skat crank,dart heads roller rockers,keith black pistons,victor jr intake and everything else you want in a engine that makes 475 horses.please serious inquires only
this one sound any good?
Transmission: 4L80E/4L80E
86CamaroDan
Sep 29, 2015 10:08 PM
