big block buick?
Old Aug 25, 2001 | 09:15 PM
gmibulldog's Avatar
big block buick?
Hi all, I have an 82 4 cylinder firebird in which I want to swap a 455 Buick engine. I'm sure its been done, I saw a third gen firebird with this same swap in hot rod a couple years ago, maybe more recent, I can't remember. I also want to swap a 200-4R in behind this engine. Can anyone offer me any advice?
spencer
Old Aug 25, 2001 | 09:27 PM
Tas's Avatar
Tas
first off, don't call it a big block.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Aug 25, 2001 | 10:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can swap any engine you want into it but only a BBC is the easiest to do. Buick, Pontiac, Oldsmobile and Caddy engines all use a different bellhousing bolt pattern so you'll also need to change your transmission to one that fits to the engine. I'm not sure about Buick GN cars if their transmission have the B-O-P pattern or if it's a standard chev pattern.
Since there's no engine swap kit available, you'll have to fabricate everything for the swap. No headers are available. Clearances and mounting brackets need to be checked.
Nothing is impossible but you'll need to do a lot of planning and be prepared to modify things to get them to work.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 26, 2001 | 09:47 AM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
As mentioned already, you'll have to make all sorts of little things and some big things, too. The header issue *might* be easier if you take a SBC header and cut and weld a Buick flange to them. The 200 has a BOP pattern but doesn't have the provision for the torque arm mounting but the GNX had a torque arm suspension and I believe Cottons? or someone has a reproduction kit available that might be of some help. One thing to watch out for with those Big Buick engines is monster torque output so build the rest of the car accordingly if you plan to hot rod the engine.
Old Aug 26, 2001 | 10:21 AM
jms's Avatar
jms
Buick did have a small-block and a big-block engine in the mid 60's to mid '70s.
I (believe) the 300, 340, and 350 were small-blocks.
The big-block versions were 400, 430 and 455s.
The other larger Buick engines in the early to mid-60s were the 'nail-head' versions that evolved out of the early 1950s design.
The early 60s small V-8 (215) was very similar between the Buick version and the Olds version. The Buick was (if I remember correctly) an aluminum-headed cast-iron block while the Olds version was all-aluminum, which was available with an optional turbocharger.
Interestingly, GM sold the design rights to the small Buick/Olds engine and it is still in production today in the Range-Rover!
Also, there was nothing like looking under the hood of a '64 full-size Buick wagon and seeing 2-4 barrel carbs! Factory Stock!
jms
[This message has been edited by jms (edited August 26, 2001).]
Old Aug 26, 2001 | 10:56 AM
gmibulldog's Avatar
thanks for all the input! i was planning on a lot of fabrication, so that's not really a surprise. I'll look into the torque arm mounting on the 200, good point. I was planning on using the stock exhaust manifolds. anyhow, thanks again for the input!
spencer
Old Aug 26, 2001 | 12:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I saw such a setup out at Bandimere a few weeks ago. I believe it ran in the 16's. Maybe it was 15.9's. Impressive...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 26, 2001 | 12:21 PM
BigL350's Avatar
There was a GTA with a 455 in either hot rod or car craft a few months ago. Looked pretty wicked. Spohn should be a big help with that. They make a TH200r4 crossmember that has a mount for their adjustable torque arm. Headers might be a PITA. Motor mounts shouldn't be that big of a deal. Driveshaft probbly won't be the right lenth. I would look for some info on a TH350 swap just because the two tranny's are almost the same lenth. 86-88 TH200r4's are supposed to be the strong ones. You'll have to get a lockup kit. Sometime soon I should be putting one on the TH200r4 going into my 79 malibu. That's all I can think of at the moment. There's a guy on the MonteCarloSS.com message board who has a 455 in his monte. His member name is Supernova455, maybe he can help.
Old Aug 26, 2001 | 11:49 PM
b92z28's Avatar
run a b-o-p turbo 400 with a hurst turbo 400 swap kit. no headers available but you can get some custom made ones.
92 z28 170,000 miles 14.20 on goodyear eagles before exhaust only mods k&n and slp 13/4 headers and dual 2 1/2 exhaust
87 trans am 12.20 on motor too many mods to list
Old Aug 27, 2001 | 03:22 AM
Tas's Avatar
Tas
hmm... I thought it was one block like Pontiac...oh well
gta892000
Aug 11, 2019 11:16 AM
sleprock
Oct 1, 2015 09:39 AM
RyanJB
Sep 14, 2015 03:39 PM
Nick McCardle
Sep 10, 2015 08:36 PM
