My first motor swap, tips from experts needed!!
I think the topic pretty much sums it up. I will be swapping the 350 from my 89 RS into My 91 RS. I will be installing Hooker 2055's, 180 deg stat,and fan switch at the same time. I am buying an engine hoist in the next couple of days.
Do I need to take off all the accessories, or can I leave them on and take out the radiator?
Basically, I need to know S.O.P. for an motor swap.
89 RS 350 TBI auto Hooker SC/LT headers Open element 3in K&N CVT protorque mini-starter
Daily driver 91 RS auto LO3 63k
New project- 89 Formula 350 WS6
383 or 400 to come!
383 or 400 to come!
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Yes, you can install the motor with the accessories attached. Since you are buying an engine hoist, I might suggest you get another tool that would connect to the hoist. Summit sells them, they call it an engine tilter/engine loader. This would allow you to make the fine adjustment need to slide your motor into your engine compartment.
Transmission: 4L80E/4L80E
I fully agree with 86z/92rs's recommendation on the tilt sling. It's great to have for any engine pull/install, whether "switch" or "swap".
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited August 26, 2001).]
The hoist I'm buying comes with the tilter. I'm getting one from Advanced Auto Parts for $220.
Any other tips?
Also, I know there is a site where you can enter the engine casting numbers and find out the year, etc. of the engine. Anybody have this link handy?
383 or 400 to come!
Any other tips?
383 or 400 to come!
Someone has to know!!
383 or 400 to come!
383 or 400 to come!
I guess not.
383 or 400 to come!
383 or 400 to come!
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
www.mortec.com
That should pretty much give you all the info that you're looking for.
AJ
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford Punch 100. 1 - MTX 12" sub
AJ
air cleaner
-B&M TransPak
-Jet Stage2 Chip
Thanks for the info guys.
383 or 400 to come!
383 or 400 to come!
Check out my new thread "This sucks a big one!" For the results of my motor pull.
383 or 400 to come!
383 or 400 to come!
