Best cam with Vortec heads on a 355??
Old Sep 27, 2001 | 09:03 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
anyone know??
oh and im prolly gonna keep the stock Q-jet and get a performer RPM intake manifold (vortex style of course)
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Old Sep 28, 2001 | 05:36 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Matt,
chevy High Performance did a build up with Vortec heads. It was like a 4 part project. I know these heads flow real well at .500", so look for a cam with that much lift. Duration is another matter. I chose a roller cam from Comp Cams. It depends a lot on the car, compression ratio, gearing, and so forth. If you know what all these variables are, then it would be easier to advise on a cam to use.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust,Dynomax Bullet Mufflers, T&R Motorsports custom air intake
Old Sep 28, 2001 | 10:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those heads don't reliably support lift above about .480" without doing machine work. The problem is that the retainers hit the top of the valve guides.
Alot of people (including the magazine articles) use the Comp XE268H with them and get HP numbers in the 400 range, with a 750 CFM Holley or Demon carb, a Perforer RPM, and headers. That sounds pretty good to me for a no-bucks buildup. Expect about 20-25 less HP with the Q-Jet but better mileage and maybe better driveability.
ICON Motorsports
Old Sep 29, 2001 | 12:40 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah i was wonderin if i could just put my CC-Q jet on there
or will i have to do some stuff to it??
and thanks for the advice everyone
Mods-
K&N Air filter
Old Sep 29, 2001 | 07:37 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
my cam works well, do yourself a favor and dump that cc-qj. A demon 625 or 750 (I have one) would work quite nicely
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000rpm stall converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
13.0 @ 107- N/A
12.5@ 117- 100HP Nitrous
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Sep 30, 2001 | 01:32 AM
JPrevost's Avatar
Car: 91 Red Sled
I'm no wiz kid but isn't the q-jet a spread bore and isn't the RPM intake a square bore? You might want to go with a square bore carb if that's the case.
, Jon (350 TBI!)
91 Red My website
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
bamaboy0323
Sep 3, 2015 06:07 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
